The Imperial Relief Forces (Imperium Alliance Thread)
For older stuff.
Arnathos
Post by Arnathos » Sat Oct 18, 2014 2:57 am
(2 months ago)
+++ INCOMING TRANSMISSION +++
+++ PRIORITY: ALPHA ALPHA LAMBDA +++
+++ FROM: SEGMENTUM COMMAND +++
+++ CONFIRMATION CODE: 49472610-2874-11 +++
+++ SUBJECT: Rebellion +++
Attention all Imperial Guard regiments near the Nova Armenian Sector. We have received word from Inquisitors Marius Rex and Helynna Valeria that there is a full scale civil uprising in the sector.
All available regiments should set course for the Nova Armenian Sector immediately and quell this uprising by any means necessary!
Thought of the Day: Compromise is akin to surrender.
+++ TRANSMISSION ENDS +++
This is General Ulysses Coehorn of the 27th Geldern Regiment, we should arrive in sector within a few days. We received word of an uprising yesterday in the Nova Armenian Sector and we have been tasked to quell the uprising by any means necessary. This should all be pretty routine, get your gear in order and fleet wide drills will be held every 6 hours until we arrive.
We are only a short warp jump away from our target, so say your prayers to the Emperor men.
Ave Imperator!
ROSTER:
General Ulysses Coehorn, 27th Geldern Regiment
WH40k:
IG 5000pts[95% Painted]
WHFB:
Empire 5000pts[95% Painted]
Arnathos
Re: The Imperial Relief Forces (Imperium Alliance Thread)
Post by Arnathos » Tue Oct 21, 2014 1:29 pm
<< Attention all hands! Prepare for Realspace entry! >> Lord Commissar Jenssen bellowed over the comms. Both the ship crew and soldiers scuttled to their seats and buckled themselves in. They had been travelling through the warp for only a short while, but everyone seemed eager to return to Realspace. Many of the soldiers were fresh from the barracks, never having seen combat. The death rate in the 27th Geldern regiment was a bit higher than most Imperial Guard regiments, but thanks to inspiring speeches from both General Coehorn and Jenssen the men were sure that they would face a different fate.
It was only moments before the fleet left the Warp, arcs of warp energy still crackling across the hulls of the ships, the fleets navigators wasted no time in getting their bearings.
Coehorn sped towards the CNC of the fleets capital ship, a massive Emperor Class battleship called Ignus Solaris. As he entered the CNC, the fleets admiral and Jenssen were having a heated discussion with the ships navigator. << Where in the Emperor’s name are we?! This isn’t Izai! We are in the middle of nowhere! >> The admiral bellowed. The navigators replied in a calm monotonous manner: << My lord, I have confirmed our position with the Astronomican as well as the other navigators in the fleet, we are indeed, at the planet Izai. >> Before the admiral could respond Coehorn interrupted the conversation. << You mean to say that both Izai and the naval base at its moon have just disappeared? >> << Correct. >> The faces of the assembled men grew pale. What could have caused such a catastrophe? After a few seconds the Admiral composed himself. << Send out a message on all imperial frequencies and see if we get any response from the sub-sector Vigilai, an entire sub-sector can’t just disappear. >>
The communications officers went to work straight away. It was not long before they realized the situation they were in. Their 3 days in the warp had been 2 months in real time. Scattered signals were coming in from throughout the sector. Few if any planets were under Imperial control and both xenos and heretics ran rampant throughout the entire Nova Armenia sector. Orders from Segmentum Command were clear, but this was no longer an uprising, this had turned into a full scale war. If they wanted to make a difference in the sector, they would need more men and equipment.
The decision was made to split up the fleet, part of it set a course for sub-sector Axile and the rest would stay in sub-sector Vigilai and try to evacuate the planet Kezvo.
Planet fall has been made on both Chantilix and Kezvo, although it was costly. Hopefully the efforts of the relief forces does not come in vain.
Present Day
+++ PRIORITY: ALPHA +++
+++ FROM: IGNUS SOLARIS +++
+++ CONFIRMATION CODE: 28753618-5479-23 +++
+++ SUBJECT: RALLYING CALL +++
This is General Ulysses Coehorn to all Imperial forces still loyal to the Emperor, we have been sent here to help save Nova Armenia from anarchy. The sector has been overrun by heretics, xenos and xeno sympathizers. Only with faith in the Emperor and by honoring our duty to protect humanity against all threats, both from within and without can we hope to achieve victory.
Our main priority is to evacuate as many assets as possible. We will try to evacuate civilians when we can. Any help would be greatly appreciated, any opposition will be crushed without mercy.
Defenders of humanity, unite!
Ave Imperator!
Thought of the Day: Only in death does duty end.
WH40k:
WHFB:
Arkrove
Post by Arkrove » Wed Oct 22, 2014 11:34 am
*BLAM* It's over. It's all over now ..... for now
"The only good is knowledge and the only evil is ignorance."
"If the path to salvation leads through the halls of purgatory, then so be it."
Arkrove
Post by Arkrove » Fri Oct 24, 2014 2:06 am
Damit.
*constructs warp portal and jumps through it.*
If you can't beat them, get as far away as you can.
Hedonismbot
Post by Hedonismbot » Fri Oct 24, 2014 9:09 pm
No, it's if you can't beat them, beat them harder!
Aug 31st 2010 10:48 am 5267 and counting.
Arkrove
Post by Arkrove » Sat Oct 25, 2014 4:31 am
Alright then, if you insist :P
*a warp portal re-opens and a whole fleet of ships emerge. First battle cannons shoot at the area where LT Dead Viper is located. A orbital bombardment then strikes down at the same area. A virus bomb shoots down shortly after that destroying all organic life on the planet. Then an Exterminatus finishes it off destroying the planet.*
If that doesn't kill him I don't know what will. Although that is usually considered overkill you insisted that I beat them harder :lol:
Arnathos
Post by Arnathos » Sat Oct 25, 2014 5:57 am
Arkrove wrote:Alright then, if you insist :P
+++ PRIORITY: OMEGA +++
+++ CONFIRMATION CODE: 37713671-5378-57 +++
+++ SUBJECT: NOT SO FAST HERETIC +++
This is General Ulysses Coehorn, Commander of the Imperial Guard relief forces, we regret to inform you, that Lt. Dead Viper, his men, as well as most of the remaining civilian population are now safely aboard our navy vessels and transports. No amount of virus bombing or Exterminatus will do you any good.
I also believe you do not have the authorization to preform an Exterminatus, nor do you have any actual presence in sub sector Vigilai.
Now stop broadcasting on our comm channels or you will not be long for this universe, you warp spawned heathen.
Thought of the Day: Heresy grows from idleness.
+++ TRANSMISSION END +++
+++ PRIORITY: ALPHA ALPHA PRIMARIS +++
+++ CONFIRMATION CODE: 576943169-1469-69 +++
+++ SUBJECT: GENERAL ALERT +++
This is General Coehorn to all imperial citizens, we have detected energy spikes coming from the Whitestone fortress and believe it will once again fire its main weapon. We have evacuated Kezvo, but we will be unable to evacuate Sub-Sectors Yina and Axile in time.
We ask all Imperial Commanders to evacuate their forces as soon as possible. We ask all those loyal to the Emperor to join us so we might stand a chance at taking on the Whitestone fortress.
May the Emperor protect us all
Thought of the Day: Faith is our Shield.
WH40k:
WHFB:
Arkrove
Post by Arkrove » Sat Oct 25, 2014 8:46 am
Damit
Hedonismbot
Post by Hedonismbot » Sat Oct 25, 2014 10:15 am
First rule of 40k, there is no such thing as overkill.
