Coalition of Armies Against the Imperium
For older stuff.
Necrons 4eva
Re: Coalition of armies against the imperium.
Post by Necrons 4eva » Wed Oct 01, 2014 10:05 am
Difference is, my ego is backed by honor and skill. Hers is backed by deceit and treachery. Don't worry, scum, the necrons have prevailed and won before, I have no doubt we will do it again. And if a deathwatch team comes my way, I've got a jack (or should I say C'tan) up my sleeve. I don't think they would be prepared for that.
Necrons, Resocakh dynasty.
6255 WYSIWYG almost all painted
Chaos Space Marines, 2nd legion
~7000 WYSIWYG half painted
"It isn't the army, its the player."
"Plans are nothing, planning is everything."
Hedonismbot
Post by Hedonismbot » Wed Oct 01, 2014 10:43 am
I think you mean to say that I'm backed by my good looks and superior intellect, not to mention that I can I'm not plagued by bad grammar!
Aug 31st 2010 10:48 am 5267 and counting.
Necrons 4eva
Post by Necrons 4eva » Wed Oct 01, 2014 7:29 pm
CURSE YOU AUTO CANNON!!!!!
Wait....
*AUTOCORRECT!!!!!!
Lionic
Location: somewher over the prysmatic refection of visible light in dihydrogen monoxide percipitaition
Post by Lionic » Thu Oct 02, 2014 7:24 pm
*hive fleet drifting though the void*
there's less drama when your a tyranid
The question is, do oil your war machines... or feed them
Hedonismbot
Post by Hedonismbot » Thu Oct 02, 2014 10:13 pm
There's also less of them signing up for the campaign!
Necrons 4eva
Post by Necrons 4eva » Fri Oct 03, 2014 6:41 am
Hint hint. Nudge nudge.
Arkrove
Re: Coalition of Armies Against the Imperium
Post by Arkrove » Sat Oct 18, 2014 3:14 pm
Hey there guys I was just wondering if I could join the 'Coalition of Armies Against the Imperium' (CAAI) here is the stuff I did when filling out when I registered my commander.
Arkrove wrote:1) What race is your commander?
Human
2) What faction does your commander fight for?
Thousand Sons
3) What subfaction does your commander fight for?
Prodigal Sons, Corvidae Cult, 6th Fellowship
4) What is your commander’s name?
Ahotep
5) Describe your commander’s personality:
During most days Ahotep is a kind and generous leader. He is open minded, cares very deeply for his fellow comrades and has enthusiasm to learn more about psychic lore. He displays qualities of a good commander and a good follower. When it comes to battle situations he is very determined and he is very knowledgable on battle situations and tactics. He is cold and calculating and tries to maximise his chance of victory success while not risking his solders lives in foolish acts of bravado.
His major goal in life is to work towards curing the Legion of the Rubric while not risking them to the mutations they were previously at risk with before the Rubric was cast. To do this he allied himself with Ahriman's Prodigal Sons and has been made captain of the 6th Fellowship.
6) Describe your army’s specialty as well as give some backstory on their origins and their battle record:
Like most Thousand Son warbands the Prodigal Sons specialise with the use of psychic powers. Ahotep will enter the fray without hesitation if need be but if he is not needed in a particular circumstance he will have no regrets staying aboard the Fellowship's flagship and directing the assault from above.
Although Ahotep is a member of Corvidae Cult and he is very gifted with the powers associated with the Corvidae Cult above all others Ahotep has become proficient at all cult powers. If the need arises he will use the power best needed for that circumstance without hesitation.
The Prodigal Sons, 6th Fellowship is mainly constant of foot slogging troops but will use any vehicles when necessary. Ahotep uses Cultists extensively. He uses the as fodder for his Marines, he would rather sacrifice the humans he barely knows to protect the warriors he cherishes and would die for. They also use Daemons allies when needed in particular circumstances. A mighty Daemon Prince named Xahor also serves with Ahotep under orders from Ahriman.
Although Ahotep is very open minded and makes very cold and calculating decisions his time with the Thousand Sons has changed his attitude into not trusting outside legion help. He will only use their help if desperately needed in a particular circumstance.
UNITS PRIMARILY USED
- Sorcerers
- Rubric Marines
- Cultists
- Daemons (primarily Tzeentch)
- Daemon Prince
- Chaos Space Marines
UNITS USED
- Tanks (Land Raider, Preditors ect)
- Daemon Engines (Forge fiend, Heldrake ect)
- Obliterators
- Terminators
UNITS RELUCTANTLY USED
- Cult Units (other than Rubric Marines)(e.g. Plague Marines)
7) Why has your army come to this sector?
Ahriman's recent endeavours have involved him trying to enter the Black Library of Chaos in order to cure the legion of it's curse, excel his own power and reunite the fragments of the Thousand Sons legion back together.
With Ahriman tied up with these efforts he has no time to scour the rest of the galaxy for a search for a cure and to find more sources of power for himself and his warband's elite. In order to not waste opportunities around the galaxy he has sent a handful of fellowships to designated locations by his order.
Ahotep's orders was to go to several designated systems and look for artefacts and relics that can help in his endeavour. Although with his small numbers in his fellowship he has to look for other factions to join up with and who will accept him into their alliances.
"The only good is knowledge and the only evil is ignorance."
"If the path to salvation leads through the halls of purgatory, then so be it."
Necrons 4eva
Post by Necrons 4eva » Sat Oct 18, 2014 5:07 pm
Welcome!!! You can gladly join. Although you won't be able to do much till the next phase, that's ok. With the chaos alliance gone, this is the best place for you.
mrshadowguy
Post by mrshadowguy » Sat Oct 18, 2014 5:12 pm
More Chaos forces arriving? Just as one force leaves, another one replaces it. It matters not, for we shall destroy you like we did the others.
- Farseer Karaeth
That one dude on that one forum with the Squrtile picture.
Necrons 4eva
Post by Necrons 4eva » Sat Oct 18, 2014 5:17 pm
Lot of talk for a punt eldar. After my own clashes on Evermore VII (campaign I did a whe ago), I've come to welcome chaos, and ally with them whenever I can. We used to be at odds with each other, but a threat to anyone is a threat against the CAAI. If you are serious, consider this the beginning of the end for you
mrshadowguy
Post by mrshadowguy » Sat Oct 18, 2014 5:22 pm
You attempts to threaten me are amusing. You think you can end our mighty alliance? Try your best, Necron. You are witnessing the beginning of the new Eldar empire, and all who appose it shall be crushed under us.
- Farseer Karaeth
Necrons 4eva
Post by Necrons 4eva » Sat Oct 18, 2014 5:25 pm
Because that worked so well for you last time. Can someone remind me what happened during the Great War in heaven? That's right, you were crushed. And before you say that the Ctan are gone, remember how I destroyed my separatists. And I'm just getting started. Last I checked boot crushes ant, not the other way around. The boot is coming down on you, good luck.
mrshadowguy
Post by mrshadowguy » Sat Oct 18, 2014 5:28 pm
You think we're ants in all this? Then I'm afraid you're horribly mistaken. Our race is on the dawn of a new age of prosperity, to regain what was once ours. If you think you can stop this, I welcome you to try.
- Farseer Karaeth
Hedonismbot
Post by Hedonismbot » Sat Oct 18, 2014 7:50 pm
Necrons 4eva wrote:Lot of talk for a punt eldar. After my own clashes on Evermore VII (campaign I did a whe ago), I've come to welcome chaos, and ally with them whenever I can. We used to be at odds with each other, but a threat to anyone is a threat against the CAAI. If you are serious, consider this the beginning of the end for you
She may talk a big game but she'll sure as hell back it up you grammatically challenged moving hunk of scrap.
You seem to forget who my dear Farseer has in her corner Phaeron. You bring your so called boot down and you'll be dealing with me. I've made the stormlord himself weep coolant like a little xenos inquisitor every time I've faced the Sautekh dynasty and crushed their little tin dollies like a cheap children's toy. Even your finest warrior, Vargard Obyron was little more than a mild distraction when I bested and utterly humiliated him in personal combat.
What chance do you have against one who has fought the best of your race and crushed them like it was nothing? Let's hope your calculation subroutines are better than your logic circuits.
Fyi, you lost that great war to us in the end.
Anyways, welcome to the campaign Arkrove. It's lots of fun and there's plenty of cool folks around to get to know and play alongside. If you're joining the CAAI, I'm sure their leader will help bring you up to speed. Best of luck.
