It is currently Tue May 21, 2013 9:55 pm
Post new topic Reply to topic  [ 14 posts ]
 Post subject: Primer problem
PostPosted: Sat Apr 07, 2012 10:05 pm
Ribbons Earned: Won a monthly Terrain Group BuildHas Completed 1 Terrain Group Build entryHas Completed 3 Terrain Group Build entriesHas Completed 5 Terrain Group Build entriesHas Completed 10 Terrain Group Build entriesHas Completed 5 Painting PledgesHas Completed 10 Painting PledgesHas Completed 25 Painting PledgesHas Completed 50 Painting PledgesTook part in a Painting Deathmatch Headline EventWon a Painting Deathmatch Side ChallengeCompleted a 'Mini of the Month' EntryAwarded the Awesome Medal of Awesomeness!
I was using spray primer (army painter black) and was doing a jetbike. I look down and it looks rough like sandpaper. I realize the can was just about empty. Now not sure how to fix. Very strange and have not seen it before. Is it something from the bottom of the spray can? What can I do other than dump it in green stuff and try and strip it?
Everyday is better than the next...
DE: 6300pts/3650 painted llllllllll
Eldar: 1800pts/350 painted llllllllll
DE WIP: viewtopic.php?f=58&t=76171
Terrain Log: viewtopic.php?f=7&t=80134
 Post subject: Re: Primer problem
PostPosted: Sat Apr 07, 2012 10:12 pm
Online
Ribbons Earned: Completed a Painting Deathmatch Side Challenge EntryRED FLAG: Failed to complete a Challenge.
oh, yeah... probably needed more shaking than normal, try shaving it off/down, if not just strip it and use new primer
There's no I in team, cause I'm not in a team, its all me.
Bromanced to my Brosband - FluffyFen
PostPosted: Sun Apr 08, 2012 12:27 am
That is what I figured. I have a bunch of models in simple green, I just throw this in when they are done.
PostPosted: Sun Apr 08, 2012 5:42 am
That is typical for spray cans to do that near the end of their life. I don't know what it is but it happened to me plenty. I would stop using my spray cans after they got too low and save it for terrain or bases.
PostPosted: Sun Apr 08, 2012 10:08 am
Any super secret tricks to fix it?
PostPosted: Mon Apr 09, 2012 3:54 am
Nope...
PostPosted: Mon Apr 09, 2012 9:34 am
Ah, Well...
Threw them in with the other models I am stripping. Hopefully won't be to big a deal.
PostPosted: Mon Apr 09, 2012 9:40 am
Online
yeah, you may need to sand/file it down a bit also...
PostPosted: Mon Apr 09, 2012 4:08 pm
Stripping them should work but if there is still some texture left over hit it with some fine grit sand paper to smooth it out. I would think 660 grit would be enough.
PostPosted: Mon Apr 09, 2012 7:33 pm
I find an old toothbrush works well for taking the surface down just alittle. The GW cleaning brush works well, really any plastic bristle brush will do...
Victory to the Saim Hann!
PostPosted: Mon Apr 09, 2012 7:57 pm
thanks, picked up a medium cheap electric tooth brush. Hope that will solve all my problems :D
PostPosted: Sat Apr 21, 2012 4:46 pm
Depending on the shape of the parts that need fixing, you can try microfibre sanding paper. These are used by jewellers to polish metals. The grits are extremely fine, 800, 1200, 1600, 4000, 6000, 8000 etc.; this will help smooth the surface without adding scratches to the plastic or metal model.
I've purchased from this seller before:
http://www.ebay.ca/itm/Tools-PMC-ART-Cl ... 53eb5446af
"Not everything that counts can be counted, and not everything that can be counted counts."
~ (Sign hanging in Albert Einstein's office at Princeton.)
PostPosted: Thu Apr 26, 2012 9:35 am
After a week in simple green, no love...well, lots of love between the primer and the model, so no divorce would be better wording. So, I took some 500 grit and went at it, got it tolerable and put a new coat on. There is still some texture, but I think I will try to use that to create some damage effect. It is on a jet bike, so maybe rocks or shrapnel blew into it at speed or something.
PostPosted: Thu Apr 26, 2012 12:22 pm
Good idea there nappen :)
Turning japanese i think im turning japanese i really think so
http://www.wix.com/saintyminis/saintyminis
