Joined: Mon Mar 05, 2012 5:33 pm Posts: 422 Location: The sunny UK {joke}
Use some washes for the skin and metal parts also as stated above try dry brushing on the skin. Also use some highlighting on the face to make it 'pop' and also edge highlight the blade on the weapon. Hope this helps
_________________ Turning japanese i think im turning japanese i really think so
Thanks guys, I'll try out all of your advice after I finish my current project. I didn't have any washes while painting big mek, now i do have some so let's see how it goes. Thanks again!
No problems buddy if you ever need advice this forum has it all, great selection of gamers and painters. Remember to check out and subscribe to my channel its called saintyminis
Joined: Tue Feb 15, 2011 11:50 am Posts: 314 Location: belgium, antwerp
Ribbons Earned:
the metal is indeed very good and a black wash would bring it to an other level as will a highlight do also but I wouldn't do much to it as it is already good as for the skin I would personally I would repaint it white and wash it several layers of trakka green wash but that is what I would do (you don't have to follow this) or you could drybrush with a lighter green over it and then lightly drybrush it with an even lighter green as foor nails and teeth you could use bleached bone and skull white (1part bleached bone an 2part white) or what I use (due to lack of money for paints [and yes I know its rather cheap €3] but that aside) tausept ochre and white (1part tau 5part white) for the red light on his head also highlighting enough of my babbling about how you can improve it I just want to end that for a newbie painter it already is really great and to be honest don't change this model keep it as it is now and paint your other models that way you can see how much you have evolved in your painting skills I couldn't paint at all and now I'm starting to get the hang of it and even now I'm still learning more and more so I hope I didn't offend you in any way and we all hope to see more of your work
_________________ what do you get when you take necrons and put them in orks hmmm.... maybe necrorks (robotick soulless orks with the mind of orks) my photobucket album
You didn't offend me at all, the contrary, I really appreciate the advice. Here's what I've been working on past two days, there're still some corrections and highlights to make, but i won't have much time to paint in a couple of days so decided to put it as it is now. Yeah, I know mandrakes are not the best on the table but the models are sweet
Ribbons Earned:
indeed compared to your ork its on a whole different level but indeed highlighting would be nice as then your model looks even beter so keep up the good work a small tip you could use a very light yellow on the tips of the flames (as that will give it a kind of glow but I could be wrong there are more pro's out here and they know how to let flames pop out even better like epic duck mike or blue or A luna) and use some extremely light drybrush of white on the hair to give it even an beter edge to it but so far an extremely good improvement I guess if you keep it up at this pace you would hit golden daemon level in 2years time ^^ or at least you'll be near that level hope to see more of your work
Trust me buddy the way that your painting you will soon be a brilliant painter, iv only been painting for 2 years and keep improving. Check out some of my stuff and remember if you need any tips or advice you can always PM me or email me buddy
Here's my next mandrake, this time I messed up though... I don't like the hair at all, it looks half decent in real life but it's awful in a big camera zoom Also the face looks dirty, next one will be better. And no matter how hard I'd try I can't paint the symbols on it's chest like in original GW pics, any suggestions about doing that? The lines are just soooo thin there...
To "find" all the detail on a model, here's what I do:
1) Prime the model with black primer from all angles 2) Aiming down at the model at about a 30-45 degree angle from vertical, lightly spray it with white or grey primer. Works best if the primer is used in a sweeping side-to-side motion instead of sprayed directly. Spin the model so that this is done from all sides.
I refer to step 2 as "dusting" in some of my tutorials, because you're not directly spraying the model, and you're allowing the colour to settle on raised edges. This will leave all of your deep grooves and creases dark, and basically shade everything else based on the angle. It's also really handy for creating stupidly quick highlights using two colours of spray - for example, basecoating with a green primer, and lightly dusting a yellow primer over it.
Users browsing this forum: Oceangrave0 and 2 guests
