Joined: Sat Jun 20, 2009 8:09 pm Posts: 14 Location: Fayetteville, Arkansas (USA)
Very clear instructions and tips, thanks a lot! I have never tried anything other the Simple Green since it works so well for me. Perhaps I will try brake fluid sometime. Also thanks for the warning of no smoking while using break fluid, since I smoke like a damn chimney!!
_________________ Cheers and good gaming! ~Metal Head Bard
People sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf.
I tried using brakefluid and super clean on my models...left them in overnight...and only 1 out of the 90 or so boyz/nobs I stripped had the primer come off...kind of annoying, they stripped the metal models clean though...kinda weird, maybe I primed them too much?
Thought I'd mention this. If you want to get rid of super glue, you likely won't be able to do it via any of the methods mentioned here to take off paint. However, there is a product that will help you out: It's Great Planes Debonder for CA type glues (cyanoacrylate glues ie super glue). It is safe for both plastic and metal models. With this, you can remove glue fingerprints, drips and globs quickly and cleanly without affecting other parts of the model. You could even disassemble a whole model if you needed to. All you have to do is apply the Debonder directly to the joints and seams. In a few minutes it will get a little gummy then start coming apart in short order. Note that it will not have any effect on Plastic Glue. One word of caution - it will remove any paint that it comes in contact with as well as the glue.
Joined: Mon Mar 21, 2011 3:33 pm Posts: 178 Location: Napa Valley, California
AffliKtion wrote:
Tested and confirmed simple green.
Let soak 24-36 hours and the paint comes right off metals in huge sheets. Plastics are a little tougher. Scrub once the best you can, re-soak them for another 24-36 hour period, then scrub again for comepletly clean models.
Ah, good thing I read this before making my orignal post, I'm currently using simple green for some botched priming I had done awhile ago and I was wondering why it was taking awhile for the paint to actually start come off, I'll have to dip them back in the containers again.
Thanks a ton for the tutorial, I've been wanting to fix up some of my older models that I painted ^_^
Joined: Sat Apr 02, 2011 6:41 am Posts: 4 Location: Australia, Tasmania
I gave my models a scrub with toothpaste and mouthwash and it works better then the brake fluid for me I used alcoholic stuff and micro whiting crystals from Colgate Soak the models in the mouth wash for better effect I think to clean any of aboot 100 it is $12 and they smell great
Joined: Tue May 03, 2011 3:29 pm Posts: 2 Location: UK
What a usefull post my good sir! I bought a Death Korps command squad and they all came out great!... However when I sprayed the Matt varnish on my vox caster it got caked in this flakey white stuff that would not come off! You've saved me my money and my model! shouts to whoever recommended the detol brand disinfectant as well for us English!
P.S Does anyone know how to avoid this Matt disaster in future?
Joined: Mon Mar 05, 2012 5:33 pm Posts: 422 Location: The sunny UK {joke}
Just like to state that acetone free nail polish remover does not harm plastic models as my partner uses it on her false nails and false nails are made out the same plastic as the models. Just pointing that out guys and gals
_________________ Turning japanese i think im turning japanese i really think so
Joined: Mon Jan 30, 2012 10:17 pm Posts: 4128 Location: Just outside of DC (for now, anyway)
Ribbons Earned:
So question: How much paint do you have to get off before you can reprime and move on?
I put the mini's in simple green for two days, scrubbed, wash, rinse repeat and am about to do my third scrub. It is not getting fully completed. In your exprience, how much is enough?
_________________ Everyday is better than the next...
DE: 6300pts/3650 painted llllllllll Eldar: 1800pts/350 painted llllllllll
Ribbons Earned:
Plastic ones I got off ebay, but horrible and thick paint jobs. After the first two soaks, I can see the details. It is some jetbikes, some eldar guardians and a few tau.
Will in the UK we use a product called dettol and normally leave them to soak for 24 hours then scrub them. I dont no what products you are using buddy but keep doing what you have been doing and i am sure they will come up a treat. Sorry i couldnt help further buddy
Joined: Tue Dec 15, 2009 6:22 am Posts: 2992 Location: Philadelphia, PA
Ribbons Earned:
Your brush could be too soft. Remember also do not push too hard as the bristles will spread and not do their job. I use a cheap electric toothbrush myself and it makes the process simpler. Tooth picks can help with those hard to reach spots.
I also have trouble getting chaos black spray off of plastic minis using simple green. I usually just leave what remains of it.
