Spray Paints as Primers
Numbsi
Post by Numbsi » Thu Dec 06, 2012 1:17 pm
I have painted very few models and one thing that has started to bother me is what i may be mistaken for is what is a primer?
I have simply been spraying my units with normal spraypaints and painting over that. I is only over close observation i can see the paint run and paints unevenly.
Where do I get a proper primer. GW spray paints aren't that easy to get hold of.
Bigfi
Re: Spray Paints as Primers
Post by Bigfi » Thu Dec 06, 2012 1:31 pm
I use tremclad primer from walmart with flat finish
fool me once shame on me, fool me twice... BLOOD FOR THE BLOOD GOD!
Cryx, Circle, CSM, and BA armies
Numbsi
Post by Numbsi » Thu Dec 06, 2012 1:51 pm
I can't say i've seen it in south africa but you have certainly got me on the right track. Thanks Mate.
Post by Marit Lage » Thu Dec 06, 2012 1:55 pm
I use Krylon flat black as my primer. It's always treated me well.
Bigfi
Post by Bigfi » Thu Dec 06, 2012 1:56 pm
i suggest the rust paint because it finishes much flatter
hope you find what you are looking for.
Numbsi
Post by Numbsi » Fri Dec 07, 2012 3:54 am
I got a can of rust-oleuam. Looks exactly like the one pictured above. Must by about $9?
Post by Marit Lage » Fri Dec 07, 2012 6:55 am
For that much, you're better off simply getting Army Painter or GW spray paint.
Bigfi
Post by Bigfi » Fri Dec 07, 2012 9:41 am
i've never used rustoleam before but the tremclad i posted is much better than army painter or gw. and yeah it typically costs around 8-9 dollars.
sonofkitrinos
Ribbons Earned: Has Completed 5 Painting PledgesWon a Painting Deathmatch Side ChallengeCompleted a Painting Deathmatch Side Challenge EntryRED FLAG: Failed to complete a Challenge.Placed First with a 'Mini of the Month' EntryCompleted a 'Mini of the Month' EntryCompleted an Entry for the first 'King of the Hill' challenge
Post by sonofkitrinos » Fri Dec 07, 2012 10:24 am
i use krylon. Army painter I have nothing but problems with the primer flaking off of the minis (even when minis are cleaned properly). GW is decent, though they are expensive.
I like krylon because it has a rotating nozzle so you can go vertical or horizontal spray. I also use grey as my primer because it works a lot better than straight black or white. Grey is a good medium because you can achieve the dark muted tones of black primer, while also allowing for a bright, bold spectrum that white creates.
YouTube Channel: http://www.youtube.com/user/MrHghowell?feature=mhee
Commissions : http://www.hghowel8.wix.com/amethysthobbies
Interested in commission work? Fire me a pm!
Nexus_Crawler
Post by Nexus_Crawler » Fri Dec 07, 2012 10:30 am
sonofkitrinos wrote:i use krylon. Army painter I have nothing but problems with the primer flaking off of the minis (even when minis are cleaned properly). GW is decent, though they are expensive.
Do you use the Krylon primer? or another paint? I have been having some issues with army painter and may switch.
--Necrons, Dark Angels--
Post by Marit Lage » Fri Dec 07, 2012 10:46 am
You'll want the flat Krylon paints. Black is probably the best, and is less than 5 USD a can.
Thief of Dreams
Post by Thief of Dreams » Mon Dec 10, 2012 3:57 pm
Krylon Fusion for Plastics! this is the best stuff in the world right here. Will not disappoint!
http://www.krylon.com/products/fusion_for_plastic/
