"Harvester Under Attack"
If you have questions about the rules in Primal Horizon, please post them here.
Frozt
Post by Frozt » Sat May 30, 2009 7:09 pm
I'm a command and conquer fan, plus the title suggests an idea of mine. Plausable Scenario i thought of:
Protect the Harvester! (until better name can be thought of)
A lightly armed convoy carrying goods and raw materiel needs to be escorted in a valley where it can be easily ambushed. Once it has made it through, your job will be complete. We expect that bandits will target such a high prize. As well, it will just be you on this mission. Do not bother calling for support should you be engaged, you -are- the support!
Mission is simple, get convoy truck/Rhino/some boxy vehicle from point A to point B. A squad must be in close proximity for the vehicle to move The opponent for the mission is to hijack the harvester and escort it off to one of the long board sides. (MWG has full options to edit this as they see fit, as long as they acknowlege that they used my suggestion) :mrgreen:
VC w1/L0/T0
Orks w3/L1/T1 (darn weedy gitz *lost to eldar*)
Fusebox45
Re: "Harvester Under Attack"
Post by Fusebox45 » Sun May 31, 2009 12:09 pm
(W00T! CNC FTW LULZ!) I like it, I'd deffinantly try it sometime, and you could add things like ambushes or traps. So say the truck is driving past a building, you could flip a token that would do either one of three things, nothing (this way they just don't avoid every token placed), an ambush (a squad previously not placed appears and attacks), and a trap (such as a landmine or demo charges on a bridge).
You'd place these all over the map at different choke points and such to keep the enemy on their toes, but forced to go through them, or take a longer or more dangerous route.
Exin
Post by Exin » Sun May 31, 2009 2:40 pm
A modified/converted Ork Truk would lend itself well for this.. + you could probebly pick some nice stuff up in the toys shop. Nyss Idea
Silvester10528
Post by Silvester10528 » Sun May 31, 2009 9:52 pm
Sounds like a Flames of War scenerio...
Desert Raiders - Convoy I think.
I would go for 1/35 or 1/48 scale WWII trucks - but I like the idea!
Frozt
Post by Frozt » Tue Jun 02, 2009 12:50 am
Well, once the rules are out for the game, I may try to see if i can make a PDF for it as a "fan expansion" :mrgreen:
VC w1/L0/T0
