Stuff I make for Necromunda: Shops
Talk about anything related to creating and painting cool terrain for Warhammer and other tabletop games.
THOMASME
Post by THOMASME » Fri Feb 02, 2018 5:45 pm
Gallery here: https://imgur.com/gallery/heCbN
Here is the completed structural only commission on the 2 part slums shop for #necromunda #warhammer40k #warhammer40000 As with the tenement slums building, the customer is going to be doing the painting, distressing and other dressings. This unit can be spilt and either used separately as a table corner Hollywood style facade, with the other building elsewhere on the table. Or merge them together and use them as a unit mid table. Now the details. As with all my work it is in a 28mm standard #dnd / Warhammer scale 1” = 5ft. It is designed by me in 2D AutoCAD. Cut from XPS foam insulation using a variety of tools including pens (for details), razor saws, steak knives, carpet knife, CNC router, horizontal hot wire cutter, vertical hot wire cutter and a few other methods. It is glued with PVA white glue or wood glue. It will be painted with acrylic paints. - EDIT - Yes they lock together.
More of my stuff can be seen here: https://www.facebook.com/GoblinFoundry/
