Making a list
AtlantianWarrior
Making a list
Post by AtlantianWarrior » Thu May 31, 2012 12:25 pm
The other day Im looking through the rule book on how to build a list. I find the section and read that you can field what ever you like. I was surprised that there was no structure on how to make a list. At first I found it odd(Im use to40K), then i thought about it and I like this.
What is your take on this free form of list making?
Daemon Hunters 5719+ points
Wood Elves 6426 points
'I am the Hammer'
'I am the point of His sword'
'I am the tip of His spear'
'I am the gauntlet about His fist'
'I am His sword just as He is my armour,I am His wrath just as He is my zeal'
KhorneFlakes
Re: Making a list
Post by KhorneFlakes » Thu May 31, 2012 12:30 pm
I'm new to the game as well and, after playing 40k for a year or two, I find this unstructured list style refreshing.
In my opinion, it makes room for a more strategic playstyle, allowing you to take a much different list depending on who you are facing.
Always remember to pillage BEFORE you burn
NurgleNpals
Re: Making a list
Post by NurgleNpals » Thu May 31, 2012 1:15 pm
I'm just starting as well and I think its fantastic. You have so many viable options for building an army. I'm currently working out two 50 point lists, one very jack heavy and the other troop heavy. Can't wait to see the play changes.
AtlantianWarrior
Re: Making a list
Post by AtlantianWarrior » Thu May 31, 2012 2:21 pm
Right now I have 1 warcaster, 4 warjacks, 1 unit and 6 solos. It comes out to like 40 points. Im going to have fun making lists. I think I need more warjack and unit options.
'I am the Hammer'
Mattman154
Re: Making a list
Post by Mattman154 » Thu May 31, 2012 8:42 pm
Just note, some entries do have a limit to how many you can field. This can be found under the FA portion. U = Unlimited, C = Character, # = Amount you can field.
Craaag
Ribbons Earned: Completed a 'Mini of the Month' Entry
Re: Making a list
Post by Craaag » Fri Jun 01, 2012 8:27 pm
It's what I like about this game. When I first got into minis games several years back I tried Fantasy Dwarves and I was really put off by having to buy a certain number of units that I didn't even like or want.
Warmachine and Hordes allow you to field what you like. Sure certain models are optimal and even encouraged (Warjack points) but really the only restrictions are field allowance of certain models.
Todda
Re: Making a list
Post by Todda » Sat Jun 02, 2012 5:34 pm
But as you noted you will find you will run out of points fast. I have 66 points and 2 Warcasters, so I could build a 70 point list, but I think my mix of models is more suited towards about 35 points. My last game was 25 points and it went pretty good... even though I lost. It was a close game and I failed a lot of dice rolls.
You will also find that you need combinations that work well together, so just taking 6 Solos in an army would likely not work well. You need combinations.
I made the move to professionally painting 3 years ago. I paint a good mix between speed and quality. This keeps prices low, like a typical 2K 40k army is under $500.
My painting services:https://www.facebook.com/toddabbottpainting
Craaag
Re: Making a list
Post by Craaag » Sat Jun 02, 2012 8:38 pm
I usually plan on Warcaster and 2 Heavy Warjacks, for a battle group plus maybe a light warjack if room permits. A 35 point list will also allow for a full 10 man unit and attachment of something (the fodder) and often 1-2 solos. This will fill a typical 35 point list. I ainly play Protectorate so 1 of those 2 solos is usually the 2 point choir a unit that costs the same as a solo.
Of course other factions will vary a little from that but generally pretty close to that set up for 35 pts.
namewithheld
Re: Making a list
Post by namewithheld » Sun Jun 03, 2012 12:46 am
For those of you who have ipods and i think its also available on android but i cannot verify this I would recommend that you look into a handy little app called Ibodger for building your warmahordes lists it gives you an easy to use interface for building lists as well as keeping track of your your collected models and a quick search for any rules in war-machine and hordes its quite the handy tool for anyone new to the game but please not this app well no longer be updating once warroom is released (warroom being the official privateer app serving relatively the same function) and in case anyone was wondering its free to download lbodger when last i checked.
Mattman154
Re: Making a list
Post by Mattman154 » Sun Jun 03, 2012 1:16 am
namewithheld wrote:For those of you who have ipods and i think its also available on android but i cannot verify this I would recommend that you look into a handy little app called Ibodger for building your warmahordes lists it gives you an easy to use interface for building lists as well as keeping track of your your collected models and a quick search for any rules in war-machine and hordes its quite the handy tool for anyone new to the game but please not this app well no longer be updating once warroom is released (warroom being the official privateer app serving relatively the same function) and in case anyone was wondering its free to download lbodger when last i checked.
I believe it was removed from the markets.
namewithheld
Re: Making a list
Post by namewithheld » Sun Jun 03, 2012 1:33 am
http://www.megafileupload.com/en/file/3 ... 1-ipa.html
there I put the file to the internet now you'll just have to do a manual add to your itunes.
No one can stop the signal, unless its the minions book then give up all hope...
Return to “Warmachine and Hordes”
