Help with Legion Modles.
Damn Lucky
Post by Damn Lucky » Sun Jul 05, 2009 6:16 pm
I want to add a Winged Hive Tyrant to my 40k army but do not like most convertions useing the pewter hive tyrant. I want to do better.
So I want to convert a legion of ever blight modle. Witch of these two modles is larger/Closer to the size of a normal Hive Tyrant.
http://store.miniwargaming.com/product/ ... x-set.html
http://store.miniwargaming.com/product/ ... beast.html
I'm thinking it's the Angelius I want but not 100% sure. Thank you.
Ashran
Re: Help with Legion Modles.
Post by Ashran » Mon Jul 06, 2009 1:23 am
I like the Angelius more but you're going to have your work cut out for you either route.
Good luck! :twisted:
dreadlord is a bar of the fish of the friction
I literally cried -Khornate
My Brotha from anotha motha.
I love you every time one of these threads show up. -Jason
I submit! /cower -Mike Nixon
Cazaius
Ribbons Earned: Has Completed 1 Terrain Group Build entryGroup Build Badge #4Group Build Badge #7Group Build Badge #8Has Completed 5 Painting PledgesWon a Painting Deathmatch Side ChallengeRED FLAG: Failed to complete a Challenge.
Post by Cazaius » Mon Jul 06, 2009 2:58 am
The Seraph is shorter and thinner than a Hive tyrant and forget the Angelius, too tall, too thin.
GABBEH!
Damn Lucky
Post by Damn Lucky » Mon Jul 06, 2009 9:04 pm
Cazaius wrote:The Seraph is shorter and thinner than a Hive tyrant and forget the Angelius, too tall, too thin.
Why forget the Angelius? If it's Taller then a Hive tyrant then that works and makes up for being thinner.
I'm not mixed the two kits together, I'm just doing some arm swaps. I just need something that size wise is close enought to a Hive tyrant to not screw with true LOS.
If it's taller then a hive tyrant, then that means it will probly be harder for it to get a cover save. Witch is good because it means I will not gain any unfair advantage.
I was accualy worried that the Angelius was SHORTER then a Hive tyrant! If it's taller then that means you just helped me make sure this plan is going to work! lol
Should be a Easy enough conversion, just have to use my pile of left over plastic fex scything talons and a pinning drill. Maby Green Stuff a more Tyranid like Carapace onto it.
Frozt
Post by Frozt » Tue Jul 07, 2009 4:06 am
if your a decent sculptor with green stuff, try using that on the Angelus to make it more "nid-dish" as it may look a tad out of place
VC w1/L0/T0
Orks w3/L1/T1 (darn weedy gitz *lost to eldar*)
Damn Lucky
Post by Damn Lucky » Tue Jul 07, 2009 5:13 pm
Frozt wrote:if your a decent sculptor with green stuff, try using that on the Angelus to make it more "nid-dish" as it may look a tad out of place
Making nid carapace is pretty easy once you get the hang of it.
Boon
Post by Boon » Thu Jul 09, 2009 9:33 pm
Seraph looks much more nid-esque. add some left over spines and bitz from your other nids and he should do just fine
theBoonarmies.blogspot
check it out...
new post 2/12/2011
Crazyboy
Post by Crazyboy » Thu Jul 30, 2009 10:37 am
I've seen both side-by-side, and I have to tell you., the Angelius and the other one are the same size. Roughly.
I'm self-medicated!
Live your life out loud and hope someone will hear you.
Return to “Warmachine and Hordes”
