25 points of Khador for as cheap as possible
easycompany
Ribbons Earned: Has Completed 5 Painting PledgesHas Completed 10 Painting PledgesCompleted a Painting Deathmatch Side Challenge Entry
Post by easycompany » Sun Apr 07, 2013 3:03 pm
As the title says I want to expand my Khador Battlegroup to 25 points as quick and as cheap as possible!
Suggestions?!
EDIT: What I currently have:
pSorscha
Juggernaut
Destroyer
Curahee!
baummonster
Re: 25 points of Khador for as cheap as possible
Post by baummonster » Sun Apr 07, 2013 3:30 pm
Well, a list of models you currently own would help :P
Honor I do not seek, but a worthy death must be earned
easycompany
Post by easycompany » Sun Apr 07, 2013 3:41 pm
Guess I wasn't clear on that in OP will edit that now
Curahee!
baummonster
Post by baummonster » Sun Apr 07, 2013 6:52 pm
I thought you meant the battlebox when you said battlegroup, but since that term could encompass more than that, I thought it might be better to ask first ;)
Well then. I suppose, since you want it to be cheap, you're going to stick with Sorscha. First pick would usually be Widowmakers then, which brings you up to 15 points flat.
That leaves you with 10 points to spare. Hmm, a max unit of Shocktroopers would probably be the cheapest option, if you find someone willing to sell those from the two player box. Otherwise a max unit of Winterguard, plus UA, plus Kovnik Grigorovich for 10 points combined would fit just nice as well
Eillas
Post by Eillas » Sun Apr 07, 2013 8:24 pm
I would have to same the same
Widowmakers 19.99
Full Winterguard with 2 rockets 44.99
Kovnik Joe 10.99
That puts you at about 76 dollars for 17 models that are all pretty good in the Khador army.
easycompany
Post by easycompany » Mon Apr 08, 2013 10:42 am
Great! Will this be an effective army?
Curahee!
baummonster
Post by baummonster » Mon Apr 08, 2013 11:13 am
Quite probably. The assortment of Winterguard+UA+WA+Kovnik is called "Winterguard Deathstar" for a reason afterall ;)
Fun thing is, you aren't even running the "perfect" caster for them. Using Sorscha2 or either Irusk will make them even better. But don't worry, they will do just fine in your list as well ;)
JP_is_here
Post by JP_is_here » Mon Apr 08, 2013 8:59 pm
easycompany wrote:Great! Will this be an effective army?
no... you should get assault kommandos and kosite woodsmen. They're awesome. You're opponents will tremble in fear.
juuuuuust kidding :wink:
Zweedish9
Post by Zweedish9 » Tue Apr 09, 2013 12:17 am
MOW Bombardiers will make your enemies tremble in fear....
No, no they won't.
"I want to play FOW but I can't get into the fluff"
"Nuts"
easycompany
Post by easycompany » Tue Apr 09, 2013 11:44 am
lol :) New list idea
pSorscha
Juggernaut
Destroyer
Winterguard Infantry (10)
3 Winterguard Rocketeers
Winterguard UA
Kovnik Joe
War Dog
25 points and works out cheaper than the one previously suggested. Opinions?
Curahee!
easycompany
Post by easycompany » Fri Apr 12, 2013 6:09 pm
After realising how close the tournament is, I figured I wouldn't get an army in time. Luckily, a local player has been kind enough to lend me some models! :D My two ideas for lists are:
pSorscha
Destroyer
Juggernaut
Max Winterguard Infantry
Winterguard UA
Koenig Joe
Wardog
OR
pSorscha
Juggernaut
Destroyer
Max Iron Fang Pikemen
Widowmakers
Manhunter
So, which list should I take?
Curahee!
baummonster
Post by baummonster » Fri Apr 12, 2013 6:42 pm
With no additional buffs, I'd probably go for the first list. That might also prove to be the "faster" list, in terms of activation times etc, if you play with timed turns/deathclock
