MWG's Weekly Painting Pledge 11/4-11/11
Post your painting pledges here and check your stats and totals!
Nappen
Post by Nappen » Sat Nov 04, 2017 9:13 am
Staring at a squad of grey plastic soldiers?
Got a project that's been hanging round your neck?
Need to get that brush monkey off your back?
Tired of being "that guy/gal" at the table?
With support from each other we can get these models done!
Use this thread to pledge your weekly painting commitments. A public pledge of what you will paint or model over the week.
Pledges will begin Saturday of each week. By 11:59pm Saturday of the following week, you report back and explain if you completed the pledge or not. If possible post pics of your work. If you didn't complete it, then you have to take the shame.
Your painting pledge could be anything hobby related, and you can pledge a small amount of work if you want. You may want to paint that spare dreadnought arm you've had for ages, you may want to use this pledge for mini of the month purposes, or competition entries. Choice is yours.
Please post your pledge (and your completion post) in Big Bold Font.
Rouven
Ribbons Earned: Has Completed 5 Painting PledgesHas Completed 10 Painting PledgesHas Completed 25 Painting PledgesHas Completed 50 Painting PledgesWon a Painting Deathmatch Side Challenge
Re: MWG's Weekly Painting Pledge 11/4-11/11
Post by Rouven » Sat Nov 04, 2017 10:42 am
I feel like trying something else for a change:
I pledge to paint 10 Plaguebearers.
Death Guard: 1 Malignant Plaguecaster, 2 Rhinos, Typhus, 20 Poxwalkers, 1 Beast of Nurgle, 10 Plaguebearers, 1 Predator
Dark Angels: Cypher
Shadespire: Spiteclaw's Swarm (5)
Nappen
Post by Nappen » Sun Nov 05, 2017 9:07 am
Sorry for the delay but am still working off my iPad. BUT...am in a house now, so will pledge something when I get back from the course I am at. Will have to be able to do it in a day, but will do something :)
Everything is updated. A few people getting close to the next ribbon.
Iguana1981
Post by Iguana1981 » Sun Nov 05, 2017 11:40 am
Good to hear life is starting to get back to normal(ish)
i pledge to work on my plague marine squad
Chaos ~ 679PL/11998 Dark Angels ~ 282PL/5449 Tau ~ 121PL /2152 Eldar ~ 217PL/3828
Chrissmith785 on Instagram
Mars-Crusader
Post by Mars-Crusader » Sun Nov 05, 2017 9:17 pm
I pledge to paint an Ironstrider.
Post by Guildenstern » Mon Nov 06, 2017 12:07 am
Cool Nappen =D and no worries we always appreciate your efforts!
Can't wait to see your Ironstrider Mars-Crusader!
I'm gonna Pledge to finish my Wyrd Iron Painter Elim Entry! Cuz I have to o.O lol
General-Kroll
Ribbons Earned: Has Completed 5 Painting PledgesHas Completed 10 Painting PledgesHas Completed 25 Painting PledgesTook part in a Painting Deathmatch Headline EventCompleted a Painting Deathmatch Side Challenge Entry
Post by General-Kroll » Mon Nov 06, 2017 1:39 am
I Pledge to finish at least one more Howling Banshee Model this week.
Number6
Post by Number6 » Mon Nov 06, 2017 11:07 am
I pledge to get some basing done on my Dark Angel forces.
40k Dark Angels, Harlequins/Dark Eldar
30K Emperors Children
WHF/AOS Vampire Counts
28mm Napoleonics
28mm AWI
Malifaux Ressers
Iguana1981
Post by Iguana1981 » Fri Nov 10, 2017 1:15 pm
Pledge complete.
Rouven
Post by Rouven » Sat Nov 11, 2017 11:24 am
Pledge failed. It was close, but in the end, I didn't make it. Too lazy...
Dark Angels: Cypher
Number6
Post by Number6 » Sat Nov 11, 2017 1:35 pm
Pledge Complete.
28mm Napoleonics
28mm AWI
Malifaux Ressers
Mars-Crusader
Post by Mars-Crusader » Sat Nov 11, 2017 5:03 pm
Pledge Complete
Post by Guildenstern » Mon Nov 13, 2017 9:07 pm
Man I am teh suq lately at remembering ot update these >< I did indeed finish - is in my thread, it was done on Friday too sigh. Anyways, pledge complete
Munin
Post by Munin » Fri May 11, 2018 1:01 pm
loveawake.ru wrote:
Thu May 10, 2018 12:36 pm
...I really suck at it. I use acrylics, and find that I cant seem to get the paint thinned properly. Can anyone give me a ballpark thinning ratio?
The trick is to cut your paints not just with water, but also with acrylic medium. If you use GW paints, Lahmian Medium is great because it thins in both pigment density and consistency at the same time. But otherwise, thinning with both a drop of acrylic medium (I use Liquitex matte medium) and water simultaneously usually does the trick.
WARNING: SCIENCE!
Acrylic paints are a pigment suspended in a water-soluble medium. However, that medium's behavior is strongly influenced by its pH level. Simply adding water to an acrylic paint changes its pH level, and if too much water is added, the pigment-suspending properties of the medium will be lost. This is what causes paints to "break" and separate and get all funky when you add too much water.
Additionally, there is the problem that (in English) the word "thin" is used interchangeably for two very different but occasionally related properties: consistency and opacity. As such, telling someone to "thin your paints" is actively unhelpful because it doesn't make clear which kind of "thin" you're referring to, or how that "thinness" can best be achieved.
Acrylic paints used for modeling purposes tend to have very high pigment densities, meaning a single coat will generally be very opaque. But they do this by having a relatively high-consistency ("thick") medium, meaning that unless you're careful in your application, you'll see brush-strokes and other signs of actual paint build-up. To get around this, you need to change the consistency of the paint, which you can do by adding water. Unfortunately, as mentioned above, water changes the chemical properties of the binding medium, so you may find that in order to get the paint to the desired consistency, you'll need to add medium as well as water to avoid having the paint "break." But neither water nor medium has any pigment in it, so by adding all of this other stuff to your paint, you are effectively reducing its pigment density - and thus its opacity. Which means that once your paint has the kind of consistency you want to get even coverage with no brush-strokes, it often lacks the opacity to achieve full coverage in a single coat. Hence Duncan's "two thin coats" mantra.
In general terms, what you're typically shooting for is paint that is the consistency of milk - thicker than water, but not by much. And you'll generally need to apply it in multiple coats to get the kind of color-coverage that you want. If you see your paint starting to separate, add a touch more medium to it.
JohnyWalter
Post by JohnyWalter » Thu May 17, 2018 6:29 am
I`m use GW paints as well about 5 years,
But thinking to try new paints more glow maybe something.I got a bad batch last month.
Any suggestion so far?
Thanks.
Regards Jon
