Iron warriors help. 3500 list
All discussions for Warhammer 30k (i.e. Horus Heresy), including Pre-Heresy, Heresy, and Post-Heresy go here.
Montambro
Post by Montambro » Tue Jan 24, 2017 11:38 am
Hey everyone,
I am new to 30k and to miniwargaming. I love iron warriors and want to know what you think of my list. Trying to get it all painted up soon.
Let me know what you think.
Rite of war - primarcha chosen
HQ:
490 pt Perturabo
after istavan- forge breaker
190 pt legion praetor
Cataphractii
Volkite charger
Paragon blade
Digital lasers
Iron halo
Warsmith
100 democles command rhino
command vox relay
focused bombardment
geo-locator beacon
Non compulsary
Elites:
210 pts - legion guad launcher battery
frag shells
shatter shells
troops:
255 points - legion terminator squad
cataphractii
5 x terminators
3 x chain fists
2 x power fists
combi bolters
terminator sergeant
chain fist
combi bolter
cataphractii
5 x terminators
3 x chain fists
2 x power fists
combi bolters
terminator sergeant
chain fist
combi bolter
280 point legion terminator squad
tartoros armor
5 x legion terminators
4 x pair lightning claws
1 x power fist-combi-bolter
terminator sergeant
chain fist-combi colter
200 points - legion tactical squad
bolters
nuncio vox
sgt
artificer armor
melta bombs
bolter-powerfist
rhino
extra armor
bolters
nuncio vox
sgt
artificer armor
melta bombs
bolter-powerfist
rhino
extra armor
Heavy Support:
310 - Legion Artillery Squadron
2 x medusas (stock)
715 points - Landraider proteus squadron
squadron command tank
landraider proteus
exploratory augury web
scout
additional twin linked lascannon
landraider proteus
additional twinlinked lascannon
landraider proteus
295 points - tyrant siege terminators
4 x terminators
powerfist-combibolters
cyclone missile launchers
siege master
Omni scope
power fist combi bolter
3500 points exactly
Xlv7
Re: Iron warriors help. 3500 list
Post by Xlv7 » Tue Jan 24, 2017 9:35 pm
My main concern with your list is antiflyer. I think a good option is a deredeo dreadnought. A good tactic with that is to set it up with a automatic pravaise and post it next to the tyrant seige terminators. Bam suddenly the unit has a 3++ invuln if they stay within 6 of that dred. Not to mention the deredeo itself is absurdly effective at stripping hull points off of a vehicle. I had my deredeo take 2 voidshields and 5 hull points off a mastodon in two turns. Granted Lady Luck was with me but it's a good example. Not to mention is has the ability to gain skyfire and interceptor when you want it.
Montambro
Post by Montambro » Thu Jan 26, 2017 1:03 pm
Jere is my revised list. Let me know what you think.
Have apprehensions with the size of ttran siege squad. Could use a contemptor if I lower the size. And also the small size of terminator squads
Rite of war - primarchs chosen
HQ:
490 pt Perturabo
Cataphractii
Volkite charger
Paragon blade
Digital lasers
Iron halo
Warsmith
command vox relay
focused bombardment
geo-locator beacon
Non compulsary
Elites:
210 pts - legion quad launcher battery
frag shells
shatter shells
troops:
290 points - legion terminator squad (7 total)
cataphractii
6 x terminators
3 x chain fists
3 x power fists
combi bolters
terminator sergeant
chain fist
combi bolter
cataphractii
6 x terminators
3 x chain fists
3 x power fists
combi bolters
terminator sergeant
chain fist
combi bolter
255 points - legion terminator squad (6 total)
cataphractii
5 x terminators
3 x chain fists
2 x power fists
combi bolters
terminator sergeant
Grenade harness
chain fist
combi bolter
280 point legion terminator squad (6 total, also I plan on having pert with them)
tartoros armor
terminator sergeant
165 points - legion tactical squad
bolters
nuncio vox
sgt
artificer armor
melta bombs
bolter-powerfist
bolters
nuncio vox
sgt
artificer armor
melta bombs
bolter-powerfist
Heavy Support:
2 x medusas (stock)
250 point sicaran venator
Lascannons
Armored ceramite
495 points - tyrant siege terminators (9 total in squad)
8 x terminators
siege master
Omni scope
3500 points exactly
3500 points total.
Cheers. And thanks alot.
MetalNids
Post by MetalNids » Thu Jan 26, 2017 3:41 pm
You are still lacking anti-air in the new list.
Personally I would drop the Sicaran Venator and the cut back to 5 Tyrant Siege Terminators and drop one of the regular terminator units. With the points you have, buy 1 unit of 10 Iron havocs with missile launchers, even the sgt, and give the sgt an augury scanner. Thats 365 points. Then I would also get a unit of 10 Iron Havocs with auto-cannons, even the sgt, and another augury scanner. Thats 315 points. By doing that you have the ML's that can still crack AV14 tanks AND provide anti-aircraft support. The autocannons can take out AV13 and infantry. Both units have Tank Hunter so you WILL get glances and pens each round. Plus with a BS of 5, they hit on 2's. So you will be hitting alot, no matter the target.
I would also drop the iron halo on your Preator since the Cataphracii already gives a 4++ invuln, and unlike the 40k Terminator Cpt, we don't get to reroll failed invuln saves (unless I totally missed that rule someplace).
Will all that, you still have roughly 50 points left over to buy other gear. If you can find 30 points someplace else, add 2 Rapier batteries. Those things really pump out the shots per round, and will devastate units with the number of shots that hit.
And another thing to keep in mind about your terminator squads....cataphracii armor CAN"T fire overwatch. So watch out for assaults.
I play the following Warhammer 40K armies:
Bugs
CSM
Harlequins
Cult Mechanicus
Chaos Demons
HydraulicGold2
Post by HydraulicGold2 » Tue Feb 21, 2017 11:55 pm
Hi Iron Warriors player here, and I thought I would give my opinion.
First, if you are running Siege Tyrants, I would consider a Siege Breaker in Cataphractii Armour to be an Auto include. I would drop the Praetor for him personally, as I don't see a need for a Praetor with Perturabo.
Secondly, using the Siege Breaker, buy some Phospex bombs for the Quad Launchers.
Third, go with either min or max squads of Terminators. One extra man won't make too much difference. Besides Iron Warriors ignore one of the biggest drawbacks of small units, which is the ease of causing morale tests by killing only a few models, usually with shooting. Nothing frustrates an enemy that relys on powerful shooting, like never even rolling the Morale test for casualties. Fun Fact, I've never had any of my Iron Warriors flee from the board.
My most recent list was for a 2k Tournament, and I will list here to show my take on Iron Warriors.
RoW: Pride of the Legion
Perturabo 490pts
Siege Breaker w/ Cataphractii Armour, Chainfist 140pts
Elites:
2x Iron Circle 410pts
Troops:
5 Man Terminator Squad w/ Lightning Claws, Heavy Flamer, Grenade Harness on Sgt 260pts
5 Man Terminator Squad w/ Power Fists, Plasma Blaster 215pts
6 Man Veteran Tactical Squad w/ Power Maul, Artificer Armour on Sgt, Vexilla, Meltagun 157pts
Heavy Support:
5 Man Siege Tyrant Squad w/ Chainfists, Combi-Melta on Sgt.
Tactics: I use Marksmen on the Vet Tacs, and Outflank, and only Deploy Pert and his 2 Iron Circle Bodyguards. I use them as a Focus for the Enemy, then hit them with Deepstrikers all around, starting with Turn 1, and watch the enemy put all the big Guns into Perturabo in a desperate bid to kill him before he hits Melee, and the Terminators typically weather a Fury of the Legion Attack, before charging on my turn. Siege Tyrants and Siege Breaker appear and target 1-2 Vehicles using Sgts Splitfire, and Siege Breaker giving Tank Hunters to Cyclone Missile Launchers
Just my style
