1250 PTS NIGHT LORDS LIST :3
quzzaq
Post by quzzaq » Wed Jan 24, 2018 5:48 am
What do you guys think of this list, i assembled it with what i got, i feel like i need a heavy hitter but not sure on what to get, i got some extras i didnt use at the end in case of suggestions ty on advance :D <3
(for tournament, battalion mandatory, uni faction also, no LOW or super heavy)
Nigt lords army
(slaaneshi, all have slaanesh mark)
Battalion detatchment
HQs:
Chaos lord on jumpack
power sword (murder sword)
combi melta
warlord trait: night haunters curse.
Sorcerer lord on jumpack
delightful agonies
presciense
force stave
bolt pistol
Troops:
10x chaos cultist
10x chaos cultist
heavy stubber
5x chaos space marines
missile launcher
elites
hellbrute
missile launcher
twinlinked lasscanon
5x noise marines
4x sonic blaster
1x blastmaster
fast attack
5x raptors
2 plasma pistol (champ)
2 plasma gun
10x warp talons
Flyer
helldrake
bale flammer
Extras:
terminator sorcerer lord (combi+stave)
chaos lord (2x lc)
2x Sorcerer (force stave slaaneshi)
1x blast master noise marine
2x sonic blaster noise marines
2x magnetized hellbrutes (1 lasscanon, 1 missile launcher, 4x power fist, 2x power scourge)
3x bikers (3 plasmas)
10 cultist (1 heavy stubber, 1 flammer)
5x raptors (3 meltas 2 chainsword+bolt pistol)
1 predator (4x lasscanon)
1 rhino
5 CC noise marines
1x missile launcher
1x heavy bolter
Salamand3rs4Lyfe
Re: 1250 PTS NIGHT LORDS LIST :3
Post by Salamand3rs4Lyfe » Wed Jan 24, 2018 8:44 am
First off i would take the missile launcher out of the csm squad, it is harder to hit with it if you move them and i feel like they are more effective when mobile. Second i would swap the plasma raptors with the melta raptors because the melta guns let them charge after firing while the plasma guns dont. Third off i would swap your warp talons with the predator, this gives you that heavy impact unit you were looking for and i dont quite think warp talons are as good as people want them to be just yet. Other than that the list looks pretty good
Armies i collect:
11,115pts csm The Privileged
7,268pts Salamanders
Jeffers
Post by Jeffers » Wed Jan 24, 2018 9:36 am
I have used warp talons quite abit and they just dont stack up well. A group of 5 is too fragile and you will notice a dip even when one dies.
If u want swap them for melta raptors and that skim points and swap the hell drake for the predator. Again i find the tin foil turkey doesnt pull its weight anymore.
I cant see how those noise marines are getting around or pulling their weight. They would need a rhino to be effective
Post by Koonitz » Wed Jan 24, 2018 10:17 am
Is that a Raptor specific rule, 'cause there ain't no such rule preventing you from charging after firing ANY weapon in 8th Edition.
Of course, such a rule DID exist in 7th Edition...
Salamand3rs4Lyfe
Post by Salamand3rs4Lyfe » Wed Jan 24, 2018 7:38 pm
And that is why im not an expert :lol:
I dont really play as often as I would like so my bad for not knowing my rules
Armies i collect:
quzzaq
Post by quzzaq » Thu Jan 25, 2018 2:12 am
Hi guys, i readed your suggestions. and i did some changes, in a way is a pity that the talons arent very good, point wise they are my most expensive unit at 270 vs 190 of my predator, but is okay i want to have atleast a slight chance in that tournament XD :v
hq (Here everything seems ok, so no changes)
Troops (since the missile launcher isnt worth it i dont feel the marines are either so more cultist)
2x10 cultist
2heavy stubber
1x10 cultist
flammer
elite (here everything seems ok but i added a couple noise more)
1x hellbrute (the same)
7x noise marines
6x sonic blaster
1x blastmaster
fast attack
5x raptor (plasma ones)
5x melta (melta raptors)
Heavy support
predator
4x lasscanon
I got 128 pts left and i dont know what to do with them, any suggestions with what i got?
Jeffers
Post by Jeffers » Thu Jan 25, 2018 4:56 am
Rhino for the noise marines or take the bikes due to volume of shoots and 2 wounds a piece
quzzaq
Post by quzzaq » Thu Jan 25, 2018 11:20 am
Im a little worried about flyers, very common in my local meta, do you guys think this list could work in that enviroment?.
Jeffers
Post by Jeffers » Thu Jan 25, 2018 12:07 pm
Flyers are different in the sense that now its -1 to hit unless its eldar then suspect altioc haemlocks at -3.
Your raptors with the fly keyword be key as you be able to shoot them and assault them for cc
quzzaq
Post by quzzaq » Thu Jan 25, 2018 8:31 pm
Any unit u guys think i should get? i was thinking on a maulerfiend to overcome the helldrake weakneses, or some terminators to be atramentar, any suggestion?
Jeffers
Post by Jeffers » Fri Jan 26, 2018 4:30 am
Terminators can be useful. Combi bolters are now bad if used with the strategem vetrans of the long war. Be able wound T7 guys on 4's and you get fair amount of shots at half range. Melta and plasma options are good also if you come in with your lord.
What loadout u considering or role?
Obliterators are very strong and matched up with the slaanesh strategem, you be able to shoot twice. I popped two leman russ's from deep strike and rolling decent with the D3's and deep striking
quzzaq
Post by quzzaq » Sat Jan 27, 2018 2:14 pm
Well since most of my army is ranged maybe some CC terminators could be nice i think
Jeffers
Post by Jeffers » Sun Jan 28, 2018 4:23 am
So go with power axes fir the -2ap to make sure they are killing whats in front them.
I like chain fists for the guarantee damage on maybe one or two of them.
Problem with terminators for chaos they can take alot, but can chew points pretty fast. You will need to maximise and stick to the sole role
quzzaq
Post by quzzaq » Sun Jan 28, 2018 6:29 am
Is this too crazy?:
5x terminator squad
mark of khorne
icon of wrath
champion: combi flammer+power fist
3x combi bolter+ power axe
1x heavy flammer+ power fist
238 pts,
