IG and Armor Ballistic Skill
Seeing as how all IG armor is 4+, I am trying to find a way to give that better odds. I know with a tank commander I can re-roll 1s, but I am wondering if I can drop that to 3+ with any specific skill or stratagem? It seems like the Baneblade is really all or nothing. You either slaughter, or hit nothing. Also, I am playing pure IG. I know there must be ways to lower the BS with other detachments, but I am just looking for pure in house abilities.
Thank you!
Thank you!
Re: IG and Armor Ballistic Skill
Vostroyans have a stratagem that gives you a +1 to your BS for a unit.
However, Regimental rules don't apply to Super Heavy Auxillary detachments so the best way to squeeze it in is to run it in a supreme command. Be careful if you're mixing and matching regiments because tournaments and ITC tend to force you to have to paint each detachment a different color.
- Signet-Powers
Would "overlapping fields of fire" work for a baneblade as you're using it on the enemy unit, not the baneblade itself? And it blanket covers anything with cadian keyword.
So have like a single lasgun from an infantry squad target the enemy unit, then use the strategem, then after that use the Baneblade on it. If its cadian it automatically benefits from +1.
So I built a list revolving around 1 Baneblade, 1 Shadowsword, and 1 Stormlord. It's a mock up of the unit that attacks the planet in "Shadowsword" the book. I have Pask, and a squad of Guardsmen in the Storm Lord. Works out to exactly 2000 points. If I give all three 4 sponsons, and a Storm bolter.
So If they are all cadian, and fire at the same "unit" they get +1? I thought it was "model" not "unit".
- Signet-Powers
No it only says unit
And then someone drops Alaitoc and it's - 1 to hit.
It doesn't really matter. I am going to be rolling dice by the buckets. The storm lord alone is over 40 shots. My only concern is what, if any, orders apply to baneblades? Can Pask even order a baneblade? Secondly, I am thinking about dropping the Stormlord for a Hellhammer, because I think the automatic rule with the HH will keep mobs off me far better than the BRRRRRT from the Stormlord.
What is the specific rule that allows each gun on the Bane blade to independently target different units? I know my friend is going to say they all need to target the same unit.
- Koonitz
- Ribbons Earned:
The rules for shooting are clear that every weapon in a unit (including every weapon on a single model that has multiple) may be targeted independently.
This goes for models as small as a Grot, and as large as a Warlord titan, and everything in between.
Targeting all weapons at a single unit is from 7th and was left with 7th.
HAH! A Salamander command vehicle and a Trojan Support Vehicle, which gives it re-rolls on hits and bonuses to hit! You can make a single baneblade (Shadowsword, lets be honest here) re-roll 1s?(Need hard confirm on this, anyone got IG Armor Codex from FW) and +1 to hit on a single tank in the unit.
What do you mean the Baneblade is total destruction or nothing?
I find Astra Militarum's overwhelming numbers typically balance out their poor accuracy.
Guardsmen are like ants. No matter how many get vaporized, they just keep on coming. Why can't pancakes be the same? I would pass the salt, but I just got tabled.
