Bobby G Only in death
Thegrayson123
Post by Thegrayson123 » Mon Apr 23, 2018 6:18 am
Hi Guys,
Was hoping one/some of you could help me out with a major rules argument I've had within my gaming group.
The way I understand it is. The first time Bobby G is reduced to 0 wounds, he is slain and remove do from play. You can then choose (if you have the command points available) to activate the "Only in death does duty end" stratagem allowing him to attack again and hopefully kill whatever killed him in the first place. You would then roll a dice at the end of the turn and on a 4+ you can place him back as close as possible to where he was and 1" away from any enemies.
Is this correct??
Mach-Ten
Re: Bobby G Only in death
Post by Mach-Ten » Mon Apr 23, 2018 10:30 am
the first time Roboute Guilliman is reduced to 0 wounds, roll a D6.
On a 4+ set him up again at the end of the phase, as close as possible to his previous position and more than 1" from any enemies, with D6 wounds remaining.
Use this Stratagem when an ADEPTUS ASTARTES CHARACTER is slain; that model summons the strength for one final attack, and can immediately either
________
yes this looks perfectly correct
Ronin
Post by Ronin » Mon Apr 23, 2018 7:18 pm
Hehehehe. I'll have to remember to bank those some command points for whenever that happens.
