Vindicare's Turbo Penetrator Rounds
ti9999
Post by ti9999 » Sun Aug 24, 2014 12:09 pm
So here's a head scratcher for all of you-
The old Turbo-Penetrator rounds inflicted 2 wounds only if your opponent failed the save.
The new version states - "Against all other targets, shots from a turbo-penetrator round inflict D3 Wounds, rather than just 1."
Would you take this to mean that it just drops D3 wounds onto a target, bypassing rolling to wound?
"The most merciful thing in the world, I think, is the inability of the human mind to correlate all it's contents. We live on a placid island of ignorance amidst the black seas of infinity."
-H.P. Lovecraft
Re: Vindicare's Turbo Penetrator Rounds
Post by Marit Lage » Sun Aug 24, 2014 12:24 pm
Does it have a strength value?
ti9999
Post by ti9999 » Sun Aug 24, 2014 12:45 pm
It's a sniper weapon, Str X.
The reason I'm asking is that the old version of the rule explicitly stated that it inflicted 2 wounds only if the opponent failed their save.
This version makes no mention of that whatsoever. That's the rule quoted straight from the dataslate.
I could also see it working like the old version, where the shot inflicts D3 wounds after saves are failed, but it isn't worded that way.
-H.P. Lovecraft
Post by Marit Lage » Sun Aug 24, 2014 1:47 pm
If it says it ignores saves, then it does. Otherwise, you get to make saving throws against any wounds inflicted, provided the source doesn't cut through that model's armor.
abf36
Post by abf36 » Sun Aug 24, 2014 1:59 pm
I don't think you should take the 'inflicts D3 Wounds' literally i.e. it's not saying to ignore rolling To Wound. However, now that you've mentioned it, I can't tell when it becomes the D3.
Shots (the total before rolling To Hit)
Hits (successful To Hit rolls)
Here?
Wounds (successful To Wound rolls)
Or here?
Unsaved Wounds (unsuccessful Save rolls)
AM 8K -¦- AS 4K -¦- GK 4K -¦- IH 10K -¦- DW 2K -¦- BT 2K5 -¦- OA 570 -¦- LC 1K5
Post by Marit Lage » Sun Aug 24, 2014 2:28 pm
From the looks of it, you roll to wound after the d3, considering it doesn't say after the roll to wound. So you treat it like a shot that causes multiple wounds, rather than something that doubles the wounds, like with Scabiethrax.
abf36
Post by abf36 » Sun Aug 24, 2014 2:34 pm
Marit Lage wrote:From the looks of it, you roll to wound after the d3, considering it doesn't say after the roll to wound. So you treat it like a shot that causes multiple wounds, rather than something that doubles the wounds, like with Scabiethrax.
I agree, and will treat it like this (until I have reason not to).
Aegis
Post by Aegis » Sun Aug 24, 2014 5:24 pm
I do not have the books immediately one hand, but this sounds like you roll to wound, and then it applies D3 wounds, much how some the D strength chart works. Personally, that is how I would run it.
Former MWG Leland, now just regular, old Leland. Now with more grump!
To see what I am working on, check out my Facebook page at its new address Aegisbrand Studios or just search for Leland Martel
abf36
Post by abf36 » Tue Aug 26, 2014 3:31 am
Now that I've thought about it a bit - I'm going to assume its a copy and paste brain fart, and they mean for it to work as before;
unsaved Wound becomes D3 Wounds.
MadMedek
Post by MadMedek » Tue Aug 26, 2014 6:23 pm
All it means is that a model takes d3 wounds. Nothing in that statement leads one to believe you dobt have to roll to hit and wound. Just means when you do wound roll a d3 for wounds. Which is nice unless unit is overpriced.
I have a high threshold for other peoples pain.
gladiator5198
Post by gladiator5198 » Sun Aug 31, 2014 2:12 am
Ok but what strength value would you roll with if you have to roll to wound. The way it sounds to me is that if it can potentially blow a vehicle up it will probably cause the wounds automatically
IngenuityGap
Post by IngenuityGap » Sun Aug 31, 2014 3:28 am
It's a sniper weapon, so you wound on a 4+
7th Circle Chaos Daemons
Imperial Knights House Terryn
Adeptus Mechanicus - Skitarii, Cult Mechanicus, Imperial Knights
Tau
Aegis
Post by Aegis » Sun Aug 31, 2014 12:53 pm
Depends on the ammo used. The Turbo Penetrator round is S10. There is another (the name escapes me right now) that always wounds on 2+, and then the shield breaker which would wound on a 4+ because of the sniper rules.
