Nappen's Test Venitian Ground-Complete
Nappen
Post by Nappen » Sun Oct 19, 2014 12:31 pm
Since this is an earth challenge, it fits with the next step I need to test for my venice board...the ground :D
here are all the base boards after being cut
Sample layout
baseboards being glued to foam
after being cut from the foam
dryfit congig number 1
dryfit config number 2
respect92
Re: Nappen's Test Venitian Ground
Post by respect92 » Tue Oct 21, 2014 2:56 am
Looks good so far. How big is it? Looks like each one is like 18'' x 18''
Please nerf damage of GW-prized minis.
Best regards the Wallet
Nappen
Post by Nappen » Tue Oct 21, 2014 7:42 am
I am going 12X12 for the main boards. The buildings are all about four inches in depth, so it will leave a good bit of room. The canals will be 6 inches wide. I will also do some 6X12 ground pieces and some special area pieces, in case I don't want so many canals.
respect92
Post by respect92 » Tue Oct 21, 2014 9:25 am
In other words, alot of pieces in many different sizes :)
Nappen
Post by Nappen » Tue Oct 21, 2014 7:14 pm
yep, for this though I am just doing the test piece. It will be a while before I can really hunker down and do the whole thing.
Nappen
Post by Nappen » Tue Oct 21, 2014 7:38 pm
primed it black and then put the first coat of paint on it.
dcrabb
Ribbons Earned: Won a monthly Terrain Group BuildWon 3 monthly Terrain Group BuildsMASTER BUILDER! Won 5 monthly Terrain Group Builds!Has Completed 1 Terrain Group Build entryHas Completed 3 Terrain Group Build entriesHas Completed 5 Terrain Group Build entriesHas Completed 10 Terrain Group Build entriesHas Completed 15 Terrain Group Build entriesHas Completed 5 Painting PledgesHas Completed 10 Painting Pledges
Post by dcrabb » Sat Oct 25, 2014 10:59 pm
Nap, do you use the table saw in one of the photos to cut your MDF and foam into nice perfect squares? I don't have one and my attempts to do modular boards fall short because my jig saw skills are not perfect and pieces don't line up right.
Nappen
Post by Nappen » Sat Oct 25, 2014 11:06 pm
I do for the hardboard, then I cut the foam with a blade
Nappen
Post by Nappen » Sun Oct 26, 2014 2:17 pm
so, it is done. kind of plain by itself, but a positive test for the way forward on the board.
With the test canal
Return to “Group Build 59”
