NEW MWG SERVER
For those on the MWG Minecraft Server to have a place to chat, set up events, and advertise their shops.
Krob678
NEW MWG SERVER
Post by Krob678 » Thu May 15, 2014 8:10 am
Hey its Bambino!! Just finished this morning getting the NEW MWG Attack of the B-Team server up and running. The whitelist is the same as the other server. If you can log onto the vanilla server you are on this new server. I'm holding back the IP address until we sort out some in game details. To get onto this server you need the mod........ but bambino how do I get the mod?
GO HERE!!
http://www.technicpack.net/download
Download the launcher and install the B-Team mod. This will allow access to the new server.
Ill post the IP when all in game issues are resolved!!
If you want in go apply!!!
Superior Man
Ribbons Earned: Has Completed 1 Terrain Group Build entryHas Completed 3 Terrain Group Build entriesHas Completed 5 Terrain Group Build entries
Re: NEW MWG SERVER
Post by Superior Man » Thu May 15, 2014 2:13 pm
One question about this modpack: if it has been installed, will it be set for every game I play, e.g. even for my singleplayer world or the non-modded MWG server?
Update (06/08/2016): -> Battlefleet Gothic playthrough! <-
IMMA FIRIN MAH LAZOR!!!
O o
/¯/________________________
| BLLLLLAAAAAAAAAAAAHHHH!!!
\_\¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
destuctir
Re: NEW MWG SERVER
Post by destuctir » Thu May 15, 2014 2:39 pm
Superior Man wrote:One question about this modpack: if it has been installed, will it be set for every game I play, e.g. even for my singleplayer world or the non-modded MWG server?
nope, it will be all safe. to run the modpack you have to launch through the technic launcher. if you launch through the regular minecraft starter instead it will only allow access to your vanilla worlds and servers. its basically having 2 versions of minecraft. they are completely seperate
Superior Man
Re: NEW MWG SERVER
Post by Superior Man » Thu May 15, 2014 3:45 pm
Okay, thanks. I'm downloading right dow. The amount of mods is a bit overwhelming (sometimes too much is actually too much) and I recognize only a few of them from the Yogscast videos, especially their Yoglabs series, but I'll at least give it a try.
*applies*
O o
destuctir
Re: NEW MWG SERVER
Post by destuctir » Thu May 15, 2014 3:49 pm
dont worry, part of the beauty of the modpack for me is that you dont have to do some of the mods. they have all been meshed togather so that similar things are identical between the mods which means you never run across something useless just because you dont want to do a certain mod.
Krob678
Re: NEW MWG SERVER
Post by Krob678 » Thu May 15, 2014 5:28 pm
they are a pack they all work well together. It should be a lot of fun and give everyone something different to work towards as well.
Superior Man
Re: NEW MWG SERVER
Post by Superior Man » Thu May 15, 2014 7:06 pm
It's installed and I got a nice texture pack for it too (Sphax pure bd craft 64p), but I can't even run a singleplayer world. "Shutting down internal server", the error message apparently has something to do with low memory allocation due to a wrong Java version or something. I have Win 7 64 bit version, but both my Internet Explorer and Firefox browsers are only 32 bit, for whatever reason. And they won't let me download 64 bit Java, so I have to update them first and then see what happens. I post this here because maybe others will experience the same problem, I hope I can fix it, will tell you here then.
Unfortunately this took up too much time already and I thus couldn't play on the old server as I yesterday, said, sorry.
O o
Krob678
Re: NEW MWG SERVER
Post by Krob678 » Thu May 15, 2014 7:20 pm
64.237.39.194:25865 IP FOR SERVER
Jathom
Re: NEW MWG SERVER
Post by Jathom » Tue May 20, 2014 11:21 pm
I keep getting an error saying "The following micro blocks are not installed" followed by a list that scrolls off the bottom of the screen.
scarboroughrj
Re: NEW MWG SERVER
Post by scarboroughrj » Wed May 21, 2014 12:01 am
Are you using the AotBT launcher and not the regular minecraft launcher?
Mammer244 :D
Black Templars
Necrons
Mammer244's Youtube
MWG Minecraft Servers FB
scarboroughrj
Re: NEW MWG SERVER
Post by scarboroughrj » Wed May 21, 2014 2:38 am
Also try this "you need to reset your b team pack, click on the little gear (sprocket) on the icon of the pack and click reset pack"
Mammer244 :D
Black Templars
Necrons
Mammer244's Youtube
Jathom
Re: NEW MWG SERVER
Post by Jathom » Wed May 21, 2014 6:53 pm
I don't see any option for "Reset Pack" :(
Also, is it supposed to take 30 minutes to run the installer every time you want to open it?
mkon454
Re: NEW MWG SERVER
Post by mkon454 » Thu May 22, 2014 7:31 am
No it does not take as long after the first start to load because then you already have all the mods loaded afterward.
Krob678
Re: NEW MWG SERVER
Post by Krob678 » Thu May 22, 2014 7:33 am
when you scroll over the B-Team icon there is a gear in the bottom left corner of that icon. When you click that there should be a button that says reset pack. Once its all installed and running it will do a quick verification every time you log in. Shouldn't take more than a min or two to log in once everything is installed.
