GB 47 - Take cover! = Completed
bugbait_nz
Ribbons Earned: Won a monthly Terrain Group BuildWon 3 monthly Terrain Group BuildsHas Completed 1 Terrain Group Build entryHas Completed 3 Terrain Group Build entriesHas Completed 5 Terrain Group Build entriesHas Completed 10 Terrain Group Build entries
Post by bugbait_nz » Sat Jul 13, 2013 5:29 am
Infinity need lots of terrain, lots of large pieces, and more importantly lots of small scatter pieces.
To start with I will be making small groups of barrels/oil drums.
Strips of 210 x 22mm paper + Amos glue stick and then wrapped around an AA battery.
1mm heavy paper (green) PVA glued around the top and bottom.
Solid strand network cable (UTP) with the plastic stripped off, wrapped around a battery for shape, trimmed to size and then super glued to the paper, tooth pick used to draw a blob of glue around so it creates a filet between the wire and paper.
Battery is then Blue Tack'd to card, a sharp knife is then used to cut out the circle for the top and bottom.
Leather hole punch and small craft punch used to make the caps from cardboard.
Hole drilled in the side of the barrel + paper clip that goes from one side to the other + super glue to hold it all together.
OzonesIpad
Ribbons Earned: Won a monthly Terrain Group BuildHas Completed 1 Terrain Group Build entryHas Completed 5 Painting PledgesHas Completed 10 Painting PledgesWon a Painting Deathmatch Side ChallengePlaced First with a 'Mini of the Month' Entry
Re: GB 47 - Take cover!
Post by OzonesIpad » Sat Jul 13, 2013 8:29 pm
Nice technique!
Tau 10420-11350
Gue'vesa 683
Kronor 1207
Sisters 716
Sanguine Angels 7725
I. Guard 6265
H. Elves 4038
D. Elves 3943
Lizard men 1095
Bretonnian 0 /cry
+LOTR, Warmaster, Anima Tactics, Warmahordes
bugbait_nz
Post by bugbait_nz » Wed Jul 17, 2013 5:12 am
Thanks OI
Barrells done, 9 clusters, Holts auto grey primer comes next.
Nappen
Post by Nappen » Sun Jul 21, 2013 9:07 am
I like those barrels. I think you did a tutorial at one point. I just can't find it :(
Can't wait to see them finished.
bugbait_nz
Post by bugbait_nz » Wed Jul 24, 2013 5:51 am
Colour is on, trying to get decent looking warning labels that are 4mm high is proving to be difficult.
bugbait_nz
Post by bugbait_nz » Sun Jul 28, 2013 3:14 am
Got the warning signs done
Resize the images to 240 pixels wide at 1000 dpi, and dropped them into Open Office to print at about 5mm high, I had to change the images so they would print very small, the lines on the skull were thickened, the biohaz sign had the inner image shrunk so there was more yellow surrounding it.
Painted the paper edges black, took ages but was worth the effort IMHO.
swedishchef
Ribbons Earned: Won a monthly Terrain Group BuildHas Completed 1 Terrain Group Build entryHas Completed 3 Terrain Group Build entriesHas Completed 5 Terrain Group Build entries
Post by swedishchef » Sun Jul 28, 2013 7:53 pm
Bugbait... as with every single thing I have seen you make, this is excellent. I love your attention to detail and it clearly shows in your work. Great job with these seemingly simple items.
LaughingChicken
Ribbons Earned: Has Completed 1 Terrain Group Build entryHas Completed 5 Painting Pledges
Post by LaughingChicken » Tue Jul 30, 2013 1:07 am
Wow, that is amazing!
If you don't mind me asking, how long did the assembly take on all those barrels?
bugbait_nz
Post by bugbait_nz » Tue Jul 30, 2013 6:49 am
Thanks S!
@LC the tubes are very quick to make, 1mm trim is easy, the wire either goes on first time or takes ages to flatten out and get to sit right . . . Im guessing 3-4 minutes if all goes well, I usually make the tubes and leave them overnight for the glue to set.
Dirt wash followed by rust stippling on black, dark brown, light brown and orange.
My PanO Crusader Brethren approves of the cover :D
Peregrin
Re: GB 47 - Take cover! = Completed
Post by Peregrin » Tue Jul 30, 2013 10:28 am
I need to make some 'exploding barrels' for Heavy Gear Arena.
You've inspired me!
Website - The Display Case - http://minidisp.blogspot.ca
Return to “Group Build 47”
