GB46 - Double Barrel Dice Tower
bugbait_nz
Ribbons Earned: Won a monthly Terrain Group BuildWon 3 monthly Terrain Group BuildsHas Completed 1 Terrain Group Build entryHas Completed 3 Terrain Group Build entriesHas Completed 5 Terrain Group Build entriesHas Completed 10 Terrain Group Build entries
Post by bugbait_nz » Sun Jun 09, 2013 6:23 am
Two tubes made with three partial cuts for some plastic inserts to bounce the dice around, will drop the dice in a toxic sludge pond, I dont have a final design in my head yet. . .
Infinity is all about the face to face rolls, so even when its not your turn you still get the chance to shoot back, think overwatch, only with a posibility of cancelling out all of your attackers shots!
Im hoping this wont turn out too big, I think smaller is better for Infinity.
Nappen
Re: GB46 - Double Barrel Dice Tower
Post by Nappen » Wed Jun 12, 2013 6:21 pm
Very interested in this. Can't wait to see how it turns out.
bugbait_nz
Post by bugbait_nz » Thu Jun 13, 2013 6:57 am
Thanks N
Progress
PVA weld lines on one tube
Foamboard support structure for the tubes
Fan painted and 'coolant tubes" that will go behind it and hold it in place.
bugbait_nz
Post by bugbait_nz » Wed Jun 19, 2013 4:22 pm
Progress
Cheap plastic handles used for the pipe bends and green heavy paper tubes for the pipes.
bugbait_nz
Post by bugbait_nz » Wed Jun 26, 2013 5:33 am
Slow progress
Internal foam board supports for the tubes
Based on 3mm MDF, there will be some 10mm wire mesh to add around the dice landing zone not that it needs it, the 3 internal slats in the tubes slow the dice down so there is no chance of them bouncing out.
respect92
Post by respect92 » Thu Jun 27, 2013 8:57 am
Cool
Please nerf damage of GW-prized minis.
Best regards the Wallet
Nexus_Crawler
Post by Nexus_Crawler » Thu Jun 27, 2013 9:56 am
Not too shabby!
Is there anything inside the tubes to make the dice tumble around more?
--Necrons, Dark Angels--
bugbait_nz
Post by bugbait_nz » Fri Jun 28, 2013 1:10 am
Thanks R92
@NC, if you have a look at the first pic you can see two of the three cuts that I did in the brown tube, about 1/3 the way though, I cut a CD cover to fit, these rattle the die around really good.
bugbait_nz
Post by bugbait_nz » Tue Jul 02, 2013 6:22 am
I seriously underestimated the time to paint this, so much more to do . . .
bugbait_nz
Post by bugbait_nz » Sat Jul 06, 2013 2:28 am
Ok Im mostly happy with this now! Only one week late . . .
3 drybrush layers of red, I went very bright because I knew the dirt wash would dull it down a lot.
Sludge pools are painted in a circular swirly motion going from black/green to brown, 2 layers of polyurethane varnish to make it look wet.
Signs are coated with PVA so the dirt wash would not run the printer ink.
Pipes are dry brushed from dark grey to grey then white (Im starting to use Vallejo paints, they are very very good, like GW paints used to be)
OzonesIpad
Ribbons Earned: Won a monthly Terrain Group BuildHas Completed 1 Terrain Group Build entryHas Completed 5 Painting PledgesHas Completed 10 Painting PledgesWon a Painting Deathmatch Side ChallengePlaced First with a 'Mini of the Month' Entry
Post by OzonesIpad » Sat Jul 06, 2013 2:28 pm
Love the weyland sign! Very nice touch
Tau 10420-11350
Gue'vesa 683
Kronor 1207
Sisters 716
Sanguine Angels 7725
I. Guard 6265
H. Elves 4038
D. Elves 3943
Lizard men 1095
Bretonnian 0 /cry
+LOTR, Warmaster, Anima Tactics, Warmahordes
Nexus_Crawler
Post by Nexus_Crawler » Sat Jul 06, 2013 11:22 pm
Predator technology.
Nappen
Post by Nappen » Sun Jul 07, 2013 11:22 am
Really works well with all your other terrain. I really like it.
tdawesome
Post by tdawesome » Sun Jul 07, 2013 11:25 am
Really nice. I need to build one for myself.
Return to “Group Build 46”
