Anyway, we came up with a few questions and I appologize if these have been asked before (and don't see a FAQ thread-probably is one, and I just missed it). Each of these situations had impacts on the game, so decided to ask here.
1) Difficult terrain: Do you round up or down for distance or is it an absolute 2 for 1 rule. For example if your move is 7 do you move 3, 3.5 or 4 inches in difficult terrain?
2) If an AOE hits with the required number does it suffer the -1 to strength like a ranged attack?
3) Does BTB=CC or must you make a CC attack to be considered in CC. For example, can you run ending up in BB, being unable to do anything else but be considered in CC-therefore not being able to be shot at and obtaining free strikes? The rules say in CC X or Y happens, and that you had to be in BTB to make a CC attack, but we could not find a definition of what is considered "in CC."
4) When a FO targets a unit and then another model uses the guided special rule is it only that they need not to have LOS to fire or are there any other benefits? We could not find any.
5) When using command points one option is to reroll any roll. Does this mean a single die or both dice when making an attribute test. Pros and cons each way, just wanted to make sure. We assumed it meant both.
6) Can command points be used to modify the roll for multiple wounds weapons. For example: with a D3 wounds weapon, you roll a four-can you use a command point to change that to a five, thus increasing the wounds from two to three? It is not listed under "rolls that can be modified." Would also ask if this can be rerolled using a command point as well, as the rules state reroll any roll. I would say that using RAW you could reroll it, but not modify it. Is that the intent?
7) Stealth: At the beginning of the turn can you deactivate and then reactivate stealth? The rules for each say "before movement" but does not exclude the other. So, for example, if you have stealth (3) and two of the stealth bases were lost, at the beginning of the next turn can you reveal yourself, then reactivate gaining back the two lost bases?
I do not see a rule that says you are revealed if your other bases are lost, and by keeping stealth you cannot be targeted until someone percevies you. So would be a great tactical advantage to stay stealthed, then at the beginning of each turn recharge your number of stealth bases.
8: Does a kill with the free strike rule trigger the overrun rule?
9) The rules do not state it specifically but seem clear that overrun does not "reset" the turn, so no additional attacks are gained. It only allows a move of half the move attribute using normal movement rules. It is not a "normal movement" which is followed by an action. Correct?
Thanks
