It is currently Fri May 24, 2013 4:12 am
By submitting anything on this forum you agree to allow MiniWarGaming to use any or all parts without permission and without compensation.
Post new topic Reply to topic  [ 4 posts ]
PostPosted: Sun Apr 01, 2012 2:21 am
Part 1 of 2
[Charge: 100%]
[Daily cycle download and uploads complete]
[Instructions: Salvage group S4 and Guardian unit 7G and Exterminator X4 will continue salvage of 24. Once completed, begin salvage of grid 25. Warning Biologicals are present in quantity and have been calculated as moderately dangerous. Exterminate Biologicals without damaging power source(s)]
[confirm mission parameters]
SU 66572 began the daily cycle like all the others before riding in the salvage carrier riding towards the next grid to be salvaged. This would be the 33rd time SU 66572 had been sent on an extermination mission, and like all the others no form of fear of its own demise bothered the Salvage unit. Instead a gentle reminder from its principle programing to persevere as long as possible to complete the salvager directive: the complete salvage of earth.
The scavenger carrier reached grid 24 and the hatches opened releasing the six SU’s
[Message from X4 : No Biologicals detected group S4 begin salvage mission Group 7G Patrol these coordinates. I will overwatch. Confirm?]
[Confirm X4]
SU 66572 moved to its assigned position and released his salvagites which scurried to a metal vehicle and began to rip it to smaller pieces with small bursts of potential gravity separating the pieces at the molecular level. After a few minutes the different materials were sorted and then slowly crushed under super heavy gravity “hammers.” SU 66572 began ripping a structure down with its destabilization beam before it could finish the salvage a sudden appearance of a biological appeared on its passive scanners and then a second.
[Message to X4: Two Biologicals present in current location request further instructions]
[Message to SU66572 Do not engage unless threatened do not want to alert the group of Biologicals. I am jamming communications. If you need to terminate do so with minimal auditory emissions.]
So SU 66572 continued to salvage the structure.
“Mike we are being jammed” said Justin alarmingly.
“Don’t worry kid they always jam communications when they are working. We should probably uncloak so it sees we don’t mean a threat.”
“What! Are you Flipen crazy then it will see us and salvage us.”
“Kid it’s going to detect us if we get any closer anyways. If it detects us cloaked it will cut you into little pieces with that damn beam it has. If it can cut through concrete in a matter of seconds think what it will do to your body.”
“ok ok you first”
“alright, you better start adding sirs in there or youll get a beating.”
“uh yes sir”
Mike uncloaked and after Justin saw he was safe did the same. The robot never wavered from its current task the only change was an “eye” followed them wherever they moved.
“That beam is crazy how does it work?”
“That’s what we are here for Numb nuts to capture footage of it in use”
“What if it decides we need to be salvaged with that beam? Uh sir?”
“far as I know your armors been hardened against intense gravity waves we might survive a few seconds but once the molecular bonds are severed your insides will dissolve in miliseconds. One theory says it won’t hurt at all.”
“What about the other theory?”
“What? Oh Extreme pain like you have never experienced. Go stand in front of it and record the amount of gravities that beam emits”
Justin walked up to the robot to get in front of it and reached out a hand and gently put it down on the robot. Two things happened at the same instant. Mike Screamed “WHAT THE HELL ARE YOU DOING GET BACK NOW!” the second thing Justin realized there was a claw sticking through his stomach. Justin was then flung into a wall with high force snapping his neck.
Mike opened fire at the robot before flipping his cloak on and turning to run.
SU 66572’s survival program switched on the second the biological touched it. A gravity slicer was thrust in the direction of the Biological the High gravity ripped the first molecules of the armor away the armor then resisted the gravity slicer far better than the structure. However, the gravity field was then followed with a monomolecular edge and the force of the salvager’s limb quickly ripped the armor open. The second biological shot and hit SU 66572 eight times causing minimal damage. SU 66572 could still sense the cloaked biological and followed it. The biological made the mistake of running in the open. Su 66572 fired its destabilization beam instead of separating the armor of the biological it held it in place and then brought it closer. SU 66572 saw the use of a cloaking field and began to salvage the Biological. Inside the suit Mike was Screaming.
To be continued…..
PostPosted: Sun Apr 01, 2012 6:07 am
wow that was amazing! more please! :D
PostPosted: Tue Apr 03, 2012 1:35 pm
Thanks bud! the next part is up
PostPosted: Mon Apr 23, 2012 2:51 pm
+1
