Ninja Warrior
From May 24th to August 24th, Matthew, Dave, and Mike are going to lose 30 pounds each. Join in on the "fun" here and get healthy!
jmaddux
Ribbons Earned: Has Completed 5 Painting PledgesHas Completed 10 Painting PledgesPlaced First with a 'Mini of the Month' EntryCompleted a 'Mini of the Month' Entry
Ninja Warrior
Post by jmaddux » Wed May 25, 2011 7:26 am
Im not trying to lose weight but i am actually training for Ninja Warrior. My goal is 75 push ups/sit ups/squats in 1 min, 50 pull ups 20 Hand stand push ups and run 1 mile in less than 9min to start.
Ill be making a video for ninja warrior, (not for another 3-4weeks tho) so ill post that when i get it done.
My work out
Run up and down my stairs (12 steps) 20 times.
8 sets of push ups 10 each:
Diamonds, elbows in (biceps), military (arms wide) one hand above and one below shoulders, then the opposite side. Finger tips, wrists, Wall hand stand.
Sit ups 3 sets 40 each of 2 and 10 of 1:
40 bike rider sit ups, 40 sit ups, and 10 (5 each way) circle sit ups (5 full circles 360 degrees).
80 squat thrusts.
i will be doing this work out for another 2 months before i change routines.
Nids: 14k
DE: 12k
Harlequins: 4k
KDK: 3k
SoB: 3k
genso6
Ribbons Earned: Has Completed 1 Terrain Group Build entryHas Completed 3 Terrain Group Build entriesHas Completed 5 Terrain Group Build entriesHas Completed 10 Terrain Group Build entries
Re: Ninja Warrior
Post by genso6 » Wed May 25, 2011 3:41 pm
Sounds tough, but you can do it! good luck, and make sure to show us if you get on the show!
Fantasy
Throng of Karak Hirn: 1750 points
Men of the Ostermark: 2000 points
Orcs: 2000 points
Tzeentch WoC: 1500 points
40k
Space Wolves: 2000 points
The Irongrad Renegade Alliance: 1250
Mordian 81st: 1000 points
Orks: 1250 points
Smurfyk
Re: Ninja Warrior
Post by Smurfyk » Wed May 25, 2011 4:30 pm
Change your workout sooner than that. Go for a couple weeks, or until that exercise gets comfortable or easy enough for you, then come up with something else.
Smurfyk's WIP
Eldar -12k 114-18-38 [W-D-L]
Tyranids -3k 32-8-7
High Elves - 5k
jmaddux
Re: Ninja Warrior
Post by jmaddux » Fri May 27, 2011 4:21 am
I do understand that you need to change it every4-6 weeks, from past trials i found that my body likes it better if i dont change it so much, iv seen better results. Tho i am looking at weight training bc. I dont think i'll have it in time.
Nids: 14k
DE: 12k
Harlequins: 4k
KDK: 3k
SoB: 3k
Amael
Re: Ninja Warrior
Post by Amael » Fri May 27, 2011 6:31 am
Good luck jmaddux :)
AwesomeFrancis
Re: Ninja Warrior
Post by AwesomeFrancis » Mon Nov 14, 2011 9:52 pm
Great plan bro!
Nien Jih Ssu Ch'u Chuehis the highly specialized Chinese Art of killing without leaving a trace.
ninja uniforms
