scale?
For all your conversion projects.
dragonianwolf
scale?
Post by dragonianwolf » Fri Mar 09, 2012 3:51 pm
hey all
I've bin wondering this whole time what the scale is of warhammer 40K
as most models (like cars, planes, boats,...) have a scale like 1/40cm or 1/15"
also what are the scales on other mini wargames
hope you can help
what do you get when you take necrons and put them in orks
hmmm....
maybe necrorks (robotick soulless orks with the mind of orks)
my photobucket album
BewareOfTom
Re: scale?
Post by BewareOfTom » Fri Mar 09, 2012 3:54 pm
IIRC its 28mm heroic scale (bigger hands heads etc....)
vehicles are weird... dunno if they follow a paticular "scale"... maybe something like 20-23mm?
"(Lebianism) is rather inefficient... there appear to be interface problems"
- Engelbart Kappa
Kidnapping? I call it surprise adoption!
Mortivore
Ribbons Earned: Has Completed 5 Painting PledgesWon a Painting Deathmatch Side Challenge
Re: scale?
Post by Mortivore » Fri Mar 09, 2012 4:08 pm
A space marine is roughly 30mm tall so its a scale of about 1/55. This varies between mini companies depending where they measure their miniatures too.
Vehicles are about 1/60.
1/64th is the S scale in model trains.
IRON WITHIN, IRON WITHOUT
Vault
Re: scale?
Post by Vault » Fri Mar 09, 2012 6:43 pm
Ah so I should be looking for roughly S gauge stuff? Good to know, happy I stumbled into this thread. :D
Get thee to a shrimpery!
Tau - 1849 points
Space Marines - 2333 points
Necrons - 3185 points
Tyranids - 3339 points
Orks - 1300 points
Lizardmen - 938 points
sebastionsynn
Ribbons Earned: Has Completed 1 Terrain Group Build entryCompleted a Painting Deathmatch Side Challenge Entry
Location: having lunch in the Resteraunt At The End Of The Universe.
Re: scale?
Post by sebastionsynn » Fri Mar 09, 2012 8:12 pm
for models outside the the games, like revell, monogram, moebius and so on, you want to look for 1/72nd which is noticeably smaller, but not so much that it can't be used, to 1/30th, 1/35th scale which can be a bit larger. generally the smaller the number the larger the model. so a model car at 1/10 scale would be about the size of your couch, possibly, it all depends on what scale the model makers used as well.
New research has discovered that research causes cancer in lab rats.
Assembled the model before painting?? It's not a n00b mistake, it's a training exercise to improve your painting skills
Loco9443
Re: scale?
Post by Loco9443 » Tue Mar 13, 2012 7:19 pm
1:73.2
The most common size of miniatures, as it is used by Games Workshop. While original 25 mm figures matched 1:76 models (4 mm scale or 00 gauge), there developed wide upwards variation in figure height. True 28 mm figures are close to 1:64 models (S scale), but may appear larger due to bulky sculpting and thick bases.
Please Check out and enjoy my Youtube Channel and Work in Progress from the Links below.
Youtube Channel
Work in Progress
Painting Pledges complete = 2
Falcon
Re: scale?
Post by Falcon » Sat Mar 17, 2012 10:47 pm
I find it really annoying when I compare an imperial guardsmen and a regular space marine. They are almost the same height! And they are supposbly like 8 feet tall, towering over normal men.
'Some may question your right to destroy ten billion people. But those who understand realise that you have no right to let them live.'
-In Exterminatus Extremis
LordGreeble
Ribbons Earned: Won a monthly Terrain Group BuildHas Completed 1 Terrain Group Build entryHas Completed 5 Painting PledgesWon a Painting Deathmatch Side ChallengeCompleted a Painting Deathmatch Side Challenge EntryPlaced First with a 'Mini of the Month' Entry
Re: scale?
Post by LordGreeble » Mon Mar 26, 2012 9:15 pm
this was very helpful thanks allot everyone :)
So, Wait... Your tellin me, orcs are related to mushrooms!
Check Out My Current Projects
Check Out My Gallery
sebastionsynn
Re: scale?
Post by sebastionsynn » Tue Mar 27, 2012 1:17 am
that's what forums are for, to share information and to help inspire others, so your welcome.
balangaz
Ribbons Earned: Won a monthly Terrain Group BuildHas Completed 1 Terrain Group Build entryHas Completed 3 Terrain Group Build entriesHas Completed 5 Terrain Group Build entriesHas Completed 5 Painting Pledges
Re: scale?
Post by balangaz » Tue Mar 27, 2012 11:18 pm
1:48 is about same height and half the girth. Truth GW made their own scale and every one like/uses it.
Oi, ya git! Get ya lazy arse roight into our Group Builds! Be da best Mek and loot all da pieces!
