well here is the questoin age of sigmar base over base
mouser04
Post by mouser04 » Thu Jul 16, 2015 2:56 am
So the rule says nothing bout you couldn't put your base on top of mine, but i think they're just hidden.
so if you were playing a game ,would you let them put their model[base] on top of your base,and after you had put a lot of hours and hardwork into putting that flocking on
that is the question
My answer is[PAUSE] heck no!You are not gonna DO that it's disrespectful to me ,and if you did ,ill respectfully knock your socks off if you even try to.
sillinde
Re: well here is the questoin age of sigmar base over base
Post by sillinde » Thu Jul 16, 2015 3:38 am
Then you need to houserule otherwise people could base for advantage, and alot of the newer models kind of are with their big bases.
The rules specify that the base is only there to help the model stand and are not considered part of the model. So if the rule is missing, how would you phrase that so I can't model my archers or whatever so you can't get into melee with me?
Spacefrisian
Post by Spacefrisian » Thu Jul 16, 2015 2:38 pm
Just agree upon the part where measuring is done from base to base and no stacking of bases is to be done. Its just to much hassle to do it otherwise. Model to model is pretty dumb anyway as i already figured out, eg look my sword is now....within range, simply by swinging the model 45 degrees to the left.
The clans are marching against the law
Bagpipers play the tunes of war
Death or glory I will find
Rebellion on my mind
sillinde
Post by sillinde » Fri Jul 17, 2015 4:34 am
Pivoting is movement and you can't simply pivot whenever you want. No part of the model is supposed to move further then their movement in inches.
Spacefrisian
Post by Spacefrisian » Sat Jul 18, 2015 5:34 am
sillinde wrote:Pivoting is movement and you can't simply pivot whenever you want. No part of the model is supposed to move further then their movement in inches.
It was in a combat, something with a pile in but all he did was pivot the model.
