Username:
Password:
Remember:
Login Register Forgot?
Follow:
Water Effects!? HELP?! PLEASE!
Hey al!!
i have made this piece of terrain (a pond) for my wood elf army ... but i need WATER EFFECTS!! Well i was thinking maybe i can ask MWG and hope that u can help my prolem!? PLZ
Does anyone know how to make cheap, easy and effective water effects???
i heard from somewere that ... apparenty... a 50/50 mix of PVA and Water makes great water effects... but dont know how true that is, or weather or not i want to try it on my terrain ... I NEED UR HELP!!!!!!!!!
here is the pics of the Terrain i want to use water effects in :
An Image
An Image
An Image
An Image
Log in above or Register Now to be able to post a comment and rate this content.
  Comments   Share
nudnikspilkis (5 months ago):
pretty neat
for water affects go for any cheap, thick glaze (like for wood or the outside of drop pods) apply a layer or two (wait for it tot dry inbetween). may shrink a very small bit leaving some up on the edges, but this is easily solved with more glaze!
also test it out on something unimportant first, glazes are not consistant from state to state.
+1
Kelush (5 months ago):
sweet cheers mate
da-killa (10 months ago):
u cud also use 1 part resin 2 1 part hardener and add some paint but the glue to water method is also effective
Kelush (12 months ago):
thank u soo much Iceman1923 & hthehidden .. great help i will be useing that ... thanx ^_^
hthehidden i wouldnt mind if u could post that that would help but its ok if u dont want to
matteuse (12 months ago):
sorry cant help but I realy like it so far!
Iceman1923 (12 months ago):
I agree with "hthehidden" use PVA glue, thin it a little bit (3glue:1water)and add a litte bit of paint (I love the effect made by denheb stone because the water look reeeaaaally dirty). when it dry completely put another lay of PVA glue (3:1) on. It work!!
hthehidden (12 months ago):
I painted the bottom of about 1/16 of clear plastic. Using glue tinted with paint did not work to well, but using clear watered downed glue worked well, and using not watered down glue worked too but it was foggy, I also tried hot glue, but if you use it put it down in small areas at a time, I did 1/8 inch strips, I can post the photos it you want
Ultramar-zane2011 (12 months ago):
i give my stuff like 3 layers of water downed pva glue but it is worth it tho
awesome thanx
natt85 (12 months ago):
they look a tad chipped
repaint the edges
it works
lol shows how much u listen to me. mix up a 60 40 mix of pva glue and water and add any neccesary colours to it. it works just like water effects
I have some ideas, I don't know how well they work buy you could try doing the PVA glue and tint it, or cut a circle out of a plastic container (1/8 in thick) and place that down then put glue over it, I'll try some and tell you how they work out
i was going to use reson... and i have just noticed how much has been chipped better repant and re-flock
The Apocalypse
Apocalypticon
Want to play in a 500,000 Point Apocalypse Game?
Click here to check out Apocalypticon
Advertisement
Disable Ads
About this Content
Kelush's Avatar Author: Kelush
Added: May 20, 2011
Rated: 12345 (8)
Found in:
  More From...   Related Content
Content Preview Water Base effects
by Jmaddux | rated 3.7/5.0
A really easy and cheap nice looking way to have water effects on bases and other small spaces.
Content Preview Water Effects - Artesian Well
by wilhelmkingspeak | rated 4.3/5.0
First try at water effects
Content Preview Tools of the trade: water effects
by dreamspirit | rated 5.0/5.0
hope you like it!
Content Preview Some experimentation with Water effect
by asmodeus3 | rated 5.0/5.0
Just a quick video showing an experiment with another possible product for water effects, how I d...
Content Preview How to make Liquid effects
by AlittlebitofChaos | rated 4.2/5.0
sludge, dirty water, lava..you can do it all with a few easy steps!
